Question about GE Spacemaker JVM1640SJ Microwave Oven
I need a wall mount bracket for a ge spacemaker micro, but I have no model #
  • 8,197 Answers
To get the wall mount you need to call GE here at this #.
1-866-775-4557
GTood Luck and Please Rate
Posted on Sep 10, 2009
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Removed my wall mounted microwave and could not get the microwave off the wall bracket. I now have some holes where the toggle bolts were. Will this interfere with the new installation
It's impossible to say without knowing the old model number and the new model number.
But since you posted under GE, I'll assume that's your brand.
You can download GE owner's manuals and installation instructions here.
Nov 30, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
What size bolts do i need in order to mount it under the cabinet. the bolt that comes from the cabinet into the micro
mcdevito75 here, Best Bet bring the mounting bracket and bolts recieved with the unit to your local hardware store. they will give you the correct bolts need to mount undera cabinet.
Jun 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for the spacemaker GE microwave oven model JVM164owj01
Here is the link to the installation manual. Cut and paste on the address bar of your browser. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF It is possible to do it by yourself, but its a royal pain in the a**, so have someone available to help you lift it into place and hold it while you get the screws into the cabinet above. You could use sheet rock anchors to put the mounting bracket on the back wall, but I would really suggest getting the mounting screw into wall studs instead, even if you have to drill a hole or two through the mounting bracket.
Apr 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Removal of unit from wall bracket
You can download GE installation instructions here.
Then you can see how it went up to help you get it down.
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement model for jvm152h
Please clarify which model Spacemaker Micro you have .. and Spacemaker microwave ovens can be configured to vent inside or out simply by repositioning the blower assembly prior to mounting it to the wall bracket so turn it on and determine where the vent air is being distributed ( outside or inside) ..
Oct 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removal
There are 3 mounting screws that anchor the microwave to the cabinet above it and a bracket on the wall behind it. Once you remove the mounting screws from the top, pull the oven straight out from the front and it will slide off the wall bracket.
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
548 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
