Question about HP Photosmart 2610 All-In-One InkJet Printer
Paper jams. It was pulled out from the front to fix, but then saw that could damage the printer. Now, it spools the paper halfway, then says there's a paper jam.
How to fix brother printer paper jam error
Follow the steps below to clear the paper jam.
  1. Pull the paper tray completely out of the printer.
  2. Pull the jammed paper up and out of the printer.
  3. Press the cover release button and then open the front cover.
  4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes shown below.
  5. Open the back output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7. After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  7. Close the jam clear cover. Close the back output tray.
  8. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
  9. Put the drum unit assembly back in the printer.
  10. Put the paper tray in the printer.
  11. Close the front cover.
http://support.brother.com/g/b/faqend.aspx?c=hk&lang=en&prod=hl5040_all&faqid=faq00000026_010
Sep 11, 2017 | Brother Office Equipment & Supplies
I had paperjams and i pulled out the paper from the front of the printer. I have done this more than once. I then found out recently that it was best to remove the back and pull ot the paper. Could...
I always recommend that paper jams be removed in the direction the paper would normally travel. Forcibly removing jams generally will not damage rollers, as the hardware tend to cause paper to tear before anything breaks. Removing paper jams in the wrong direction however can break one-way "finger" paper path sensors occasionally. If you are not experiencing a jam every single print, you are probably in good shape.
As for cleaning the rollers, if you have taken the rear door off the printer you are halfway there. You should be able to turn the rollers in one direction or the other by hand. There are plenty of products out there to clean rubber rollers (I use Blow-Off Rubber rejuvenator) but rubbing alcohol on a cloth can work as well. Turn the rollers to get at the entirety of them and scrub along the length with an alcohol dampened rag.
Jun 02, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Deskjet 930c; after a paper jam, the fault (middle)lamp keeps blinking. When I press it, a sheet of paper is drawn halfway through and a second press of the button completes the paper passing through. But...
there is a piece of paper left from paper jam inside the printer. open the printer in rear side portion and remove the paper inside. don't open in front of the printer it can damaged some mechanical parts of your printer.
Mar 22, 2010 | Office Equipment & Supplies
How do I fix a paper jam?
Step 1
Turn the printer off and on to see if it can automatically clear
some or all of the jam.Many printers provide an error-code listing
on the front panel display for the area where the jam occurred.If
your printer shows an error code, be sure and check the printer
manual to see if that identifies the area of the printer where the
jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path
and to the toner or ink cartridge.
Step 5
If necessary,remove the toner or ink cartridge.Place it in a bag
or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper,remove it by holding it with
both hands and pulling firmly.If several pieces are jammed together
try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear,try rotating the roller gears manually to
free the paper.
Step 8
Replace the toner or ink cartridge and paper trays,close any doors
you opened and turn the printer back on.
Step 8
If the printer paper jam message still appears,then there is still
some paper in the printer.Reinspect the paper path.
Oct 28, 2009 | HP DeskJet 810c InkJet Printer
How do I fix a paper jam? I have a piece of paper that went in slightly sideways, and now its jammed. It's almost halfway in, so I'm afraid to pull on it in case it rips and pieces are left. Is there way...
You won't be able to make the printer work backward and push the paper out. Start by powering OFF the printer (unplug it if necessary). Then look to open up the front/top/back as appropriate to clear the paper jam. Frequently, if you pull straight and carefully (slowly), the paper will come out in one piece and solve your problem. If any pieces are left inside, remove them all before attempting to power ON the printer. If in doubt as to clearing, read the user manual - troubleshooting section on clearing paper jams. Good Luck!
Aug 13, 2009 | Brother HL-2040 Laser Printer
Printer jam
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
  1. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
    Make sure that the Paper LED is now off and the printer is ready.
Apr 05, 2009 | Brother HL-2040 Laser Printer
Will not turn off, will not print text, poor quality pictures
well..this is not a happy circumstance. I must report that when the paper is pulled through from the front, it can damage some innards, which I suspect is the case here.
sounds like it's a candidate for a factory service gig.
Aug 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
HP Photosmart 2610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
