Question about RCA Alarm Clock w/CD Player, AM/FM Stereo & Nature Sounds
Cd player wont eject cd - RCA Alarm Clock w/CD Player, AM/FM Stereo & Nature Sounds
  • 776 Answers
Try this:
Starighten a paper clip and gently push it into the small hole situated usually just below the tray door until you feel some resistance: continue to push gently and the door should open slightly - enough for you to pull it open and reclaim your disk. Make sure the PC is turned off before you do this. You may then find also that the CD tray will co-operate again when you turn it back on.
Posted on Sep 10, 2009
CD Wont Eject & Mode Wont Go to "CD MODE"
I suspect that the rubber belt that drives the eject portion of the unit has broken. I suggest you remove the unit and have an teckie look at it. belts are available for most makes from tandy or other electronic parts shops.
May 09, 2013 | 2005 Honda Element
I CANT EJECT MY CD CHANGER ON MY 2000 E46 325I IT MAKES A NOISE BUT WONT EJECT, ALSO IT WONT PLAY ANY CD IN THE CHANGER, IS THERE A WAY OF MABY MANUALY EJECTING IT ? MANY THANKS, MITCH
You need to pull CD player, then remove lid (4 small screws) and you'll find CD lodged and can easily remove. Put lid back on, reinstall player and you're GOLDEN!
Jan 04, 2011 | BMW 325 Cars & Trucks
2005 malibu cd player says check disk wont eject
Unfortunately yes. This is a very common problem.
Jun 22, 2009 | 2005 Chevrolet Malibu
2004 FORD F-150 CD EJECT ERR
I've had this happen once before..CDR's are a little bigger than regular cd's.Sometimes they wont let go at all..You either can undo the battery and then reconnect then it usually automatically ejects or you'll have to manually do it or you can pull the fuse and then put it back in and the same proceedure..
Mar 28, 2009 | 2004 Ford F150
My cd player won't eject cds
you might try and look inside the CD slot with a flashlight and if you can see a CD try to remove it with tweezers,you do have power to the player right? if no power it wont eject,
Jan 11, 2009 | 2002 Ford Excursion
Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
Jan 01, 2009 | Stanton C-303 Single Top Loading CD Player...
CD WONT EJECT PIN HOLE
If it's trying to eject you may need to use a small screwwdriver to lift up on the CD. This works when mine hangs up. If it's not trying to eject at all, then the little motor on the ejecting mechanism may have failed or come off track. I had to replace the original CD player about a year ago because of this. That's why I have the JVC now, and it seems that CD's started hanging up from day one with this radio.
Jul 16, 2008 | JVC KD-G210 CD Player
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Cd wont eject.
I was having the same issue with my KD-S5050. I also tried the CD eject lock reset with no results. By using the following steps I was able to reset my CD player and it is working properly again. On page two of the user manual is shows how to do a full reset of the cd receiver. While holding SEL (Select), press ATT (Standby/On Attenuator) for more than 2 seconds. This will reset the built-in microcomputer. http://www.fixya.com/Brands/J/JVC/Manuals/kd_s5050_cd_d2ce2654fa2aab37f3ad2b4ce1e33443/images/KD_S5050_CD_D2CE2654FA2AAB37F3AD2B4CE1E33443_2_p2.jpg NOTES: ? Your preset adjustments ? such as preset channels or sound adjustments ? will also be erased. ? If a CD is in the unit, it will eject when you reset the unit. Be careful not to drop the CD.
Oct 31, 2006 | JVC KD-S5050 CD Player
RCA Alarm Clock w/CD Player, AM/FM Stereo & Nature Sounds Logo
152 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
