Question about Nvidia GeForce 7200 Graphic Card
I connect my sanyo 42 inch LCD tv via s-video, no signal on TV
I connect my sanyo 42" LCD tv via s-video cable from my Nvidia 7200 GS. Tv says no signal. What am I doing wrong?
  • 25 Answers
Be sure you changed the source on the tv (i'm guessing you did this), be sure you switch the out-put on your computer to s-video. You can do this in the properties box. If you are running the nvidia video utility, you can set up hot keys to do this. I set up ALT, Z, 3 as my hot key combination. All I do is hook up to my tv, press the three buttons above, at the same time, and the video moves from my pc monitor to the tv.
Posted on Sep 10, 2009
Want to use my 42 inch flat screen tv sanyo/ vison into my compter screen
this can be easily done via hdmi simply connect hdmi cable to tv and to hdmi output of computer you may need to set the resolution/ or interface on the computer
Apr 28, 2018 | Televison & Video
How to fix screen blur
Try another input with something else sending in a video signal.
That will help you figure out if it's the TV, a cable, or the equipment sending the signal to the TV.
Aug 16, 2016 | Sanyo 32K40 32 inch Multi-System LCD TV
Sanyo 2008 flat screen 42 inch no picture have sound
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 26, 2012 | Sanyo 42K40 42 inch Multi-System LCD TV
I have a Sanyo 42 inch Mode Number: DP42647. I bought it 2.5 years ago, and suddenly, the video is out. The sound is ok, as well as the "power" green LED. By looking at other forums, it seems...
I would just replace the TV, because any guess you make without the testing and equipment is just an expensive guess. New TV's are cheap by comparison. I have had a lot of TV'ds and the best do far is my Vizio 42 Inch LCD. 11 years old no issues.
May 20, 2017 | Sanyo 42 in. LCD TV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
GeForce 7200 GS 256MB won't work with tv
"the tv works and I can see my extended desktop, but ONLY in 800x600!!! Also when I tried to watch a movie on the tv, it only showed a black block"
1. Tv's only support max of 800x600 (technically less)
2. Windows has a built in ANTI theft BS protection that makes viewing video through an alternate output show up black boxed.
Mar 16, 2009 | Nvidia GeForce 7200 Graphic Card
Hook up
The Bose GS can only support component video set-up for the best video definition. This video connection set-up uses three RCA cables to transfer the video signal from an output device (the Bose GS) to an input device (Your TV).
Check if the back of your GS system has a set of video out RCA ports that are titled "Comp Out". You TV should then have a "Comp In" video input RCA ports you can connect to.
Hope this helps.
Oct 14, 2008 | Bose 3 2 1 GSX System
Pc to tv
Same problem for me too!
Dec 21, 2007 | LG 42LG30 42 in. LCD HDTV
Nvidia GeForce 7200 Graphic Card Logo
341 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
