Question about Toys
My 2.5 tmaxx has no drive to the wheels,no problem at clutches!
  • 88 Answers
Is the clutch bell turning the spur gear? Have you checked the slipper clutch to make sure it has not loosened? If both of these check out it could be something broken inside the transmission.
Posted on Dec 10, 2009
My rear wheel drive locks up, replaced the rear wheel drive and one of the wheels last year now problem has reappeared.
This could be a faulty switch, faulty relay, or fault clutch, or a blown fuse, usually the relay fails before the clutch, but not always
Oct 14, 2013 | Toro Power Lawn Mower
Tmaxx 3.3 starts and runs when holding off the ground but as soon as i put it on the ground it dies
Change your clutch shoes and spring, if shoes are still good,then just the spring
Mar 07, 2013 | Traxxas T Maxx 3.3 Monster Truck
Clutch replacement
Clutch replacement will requre the removal of the transmission. If it is a rear wheel drive the trans can be removed fairly easily. Front wheel drive autos have the engine and transmission mounted in a "transerve" (across) fashion and require more time for removal. rear wheel drive requires the removal of the driveshaft (not difficult) and the front wheel drive requires the removal of the drive axles( can be difficlt). If your not mechanicly inclined and have a fair assortment of tools and equipment, this job is best left to a quailified person. You need Jack stands, floor jack, transmission adaptor, and if it's a front wheel drive, you will need an inpact gun to loosen the axle nuts on the drive axles.
Jan 24, 2011 | Ford Fiesta Cars & Trucks
Clutch installation maual for 2000 ford focus ZX3
Don't have manual but here;
the clutch is located between the engine and transmission. Therefore you must separate the engine from the transmission to gain access to the clutch.
This is much more difficult on a front wheel drive vehicle.
On most front wheel drive vehicles the easiest way to this is to remove the engine and transmission as a unit. However on a front wheel drive vehicle the engine and transmission come out from the bottom. You disconnect all of the hoses, wiring, linkage, etc just like on a rear wheel drive vehicle. You disconnect the suspension and steering. You disconnect the front "K" member (front sub frame). Then if you have everything disconnected properly you lift the body off of the drive train. You can then separate the engine from the transmission and service the clutch. You reverse your steps to reinstall the engine.
As you can see this is much more involved than accessing the clutch on a rear wheel drive truck where the transmission can be removed without removing the engine.
There are a few front wheel drive GM vehicles I have seen where the "K" member can be removed in pieces. On these vehicles you only remove half of the "K" member and you can remove the transmission without removing the engine. Not sure if this is possible on a Ford.
Nov 23, 2010 | Ford Focus Cars & Trucks
How do i install a clutch in a 1982 datson pickup 4/4
front wheel drive or rear wheel drive ,reason i ask is i have changed many clutches in my time but now iam old i forget things ,but if its front wheel drive with the BMC morris B series engine then its easy to do and shouldnt take more than 15 mins to do as you only need to remove a plate on top of bellhousing then remove the spigot housing on the side and then undo each clutch bolt one at time whilst turning the flywheel ,so easy to do
Nov 05, 2010 | Datsun 720 Cars & Trucks
My traxxas tmaxx 3.3 idles alot and wont go neutral
if the car isnt staying put when idling then the clutch shoes are sticking to clutch bell.If engine is stalling then would have to retune.
Aug 05, 2010 | Traxxas T Maxx 3.3 Monster Truck
My tmaxx runs in reverse only
It could be that the "dawgs" in the f/r clutch are not pulling in totally.
Take apart the tranny, tighten the spring tension about a 1/4 turn, just like on the 2 speed clutch, on both the f/r gears.
You won't notice any difference in engagement speed but it will not get stuck in reverse mode now.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 06, 2010 | Toys
Change clutch
Sounds like transfer case issue if 4 wheel drive works and 2 wd does not. Clutch slippage would be worse in 4 wheel drive more than 2 wheel drive, more to push.
May 16, 2010 | 2003 Toyota Tacoma
Hi i want you to tell me how to replace the clutch in tmaxx 3.3 the 4 pecis
you have to remove the clutch bell an then you will have acces to replecet somemtimes you have to desmauth the engine
Apr 09, 2010 | Traxxas T Maxx 3.3 Monster Truck
Toys Logo
167 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
