Question about Kenmore 53642 / 53644 Side by Side Refrigerator
The ice won't come out mottor that turns the ice is not working.What part shoiuld I order and how do I fixed. is a kenmore model 106.56532400
  • 93 Answers
It is called an auger motor. Remove the auger motor and try to defrost it. A lot of times they will just get froze in place.
Posted on Sep 12, 2009
Fixing in door ice dispenser
What is the model number of the unit?
Nov 23, 2012 | Kenmore Side by Side Refrigerator
Ice maker is not working. doesn't appear that it's
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Have a good day : )
Sep 03, 2011 | Kenmore Side by Side Refrigerator
Ice maker will not make ice Model number
  • When it Won't Make Ice
    • 1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
    • 2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
    • 3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
    • 4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
  • Hope this tips will help you.
    Have a nice day! : )
    Aug 28, 2011 | Kenmore Refrigerators
    Ice maker in side by side Kenmore refrigerator model number 106.55529400 has stopped working.The ejector fingers are not stopping in correct position,from what I have read online this means ice maker...
    1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
    .2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
    3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
    4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
    Hope i can help you with your problem.
    Have a nice day : )
    Aug 22, 2011 | Kenmore Refrigerators
    Not cooling
    2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
    The question is too short so i guess that your refrigerator maybe won't make ice & reason for not cooling so i gave this tip.
    Have a good day. : )
    Apr 17, 2011 | Kenmore Refrigerators
    Kenmore elite ice maker stopped making ice,
    Hope thiswould help you
    Have a good day : )
    Jan 01, 2011 | Kenmore Refrigerators
    Kenmore side by side ice maker not working, water does work, checked the back not a frozen line. The problem occurred when the compressor/start device was replaced in the summer. The repairman said that...
    Hope it help you.
    Have a nice day.
    Dec 06, 2010 | Kenmore Refrigerators
    Kenmore Elite Trio 795.77563600 Ice Maker Not Working
    Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
    Jul 29, 2010 | Kenmore Refrigerators
    Kenmore ice maker problem
    I'm not sure in your case if its better to order a new ice maker or if you want to take it apart and change the thermostat or possibly the limit switches. Some have a spring so if you try to do it yourself do it slowly and carefully as not to lose the internal parts. Let me know, I will help you if you need, Sea Breeze
    Apr 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
    Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
    Mar 21, 2008 | Refrigerators
    Kenmore 53642 / 53644 Side by Side Refrigerator Logo
    188 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    dweatherby
    paulcarew
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
