Question about Whirlpool Dishwashers
I HAVE A DISHWASHER QUITE PARTNER II MODEL. THIS CLEAN LIGHT IS BLINKING AND THE DISHWASHER WILL NOT START. LAST TIME THIS HAPPENED I PUSH A SERIES OF BUTTONS ON THE FRONT OF THE MACHINE
  • tnavy93 Sep 10, 2009
    Great Job - It work. Thank yo for your quick response.
  • Whirlpool Master
  • 19,396 Answers
You have to press a series of button in sequence, the sequence is completed pressing the Hi-Temp wash, air dry, Hi-temp wash and air dry again in succession.
On some model it can be Sani Rinse wash, air dry, Sani Rinse and air dry again in succession.
If that does not work, then try tripping the circuit breaker for two minutes, emptying water that can be eventually inside the tub, connecting back, and doing the reset sequence again.
See also the diagram here.
Posted on Sep 10, 2009
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a quite partner 2 and it is stuck on the clean cycle and the light is blinking on and off. It will not work when I push any other buttons.
whirlpool dishwashers sense the water temperature in them the clean light flashing 7 times means either the heater element is not working or the water temperature going into the unit is to cold, start the water at the sink before starting the dishwasher now to get rid of the flashing light press the hi temp wash button and then the sani rinse button press one then the other over and over until all the lights come on it will then go in to a test mode when it completes the flashing light will go out that will solve your problem
Apr 03, 2010 | Whirlpool Dishwashers
Whirlpool dishwasher Quiet Partner II: Can you help me reset the "blinking clean light" indicator? Yes or no.
shut down the circuit breaker that controls the dishwasher for 20 - 30 minutes then turn it back on.
Dec 29, 2008 | Dishwashers
Whirlpool quiet partner II dishwasher is leaving chunky residue on dishes
I H AWHIRLPOOL DASHWASHER MODEL # DUII45XTPB6 quite partner ll I lost my manual , Im trying to acess the error codes . or Im trying to get the diagnostic codes to start . Hope some one can Help""""""
Oct 19, 2008 | Whirlpool Dishwashers
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
