Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Water does not dispense from tools and hose - Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
  • 34 Answers
That always happens to me to!! i know it stinks haha, well the problem is your hose is probobly filled up with debree or you didnt set the knob to tools. if it still dosent work take it to a shop,
Posted on Sep 12, 2009
2 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: I need the nylon part
If you are talking about a piece in the handle of the hose, you may have to replace the whole hose asm. part number 90001336. A repairshop should be able to see if you can just the piece you need, if it is available by itself.
Posted on May 09, 2008
Hoover troubleshooting
Hi! Try these quick and easy steps to get the water from your hose to spray.
Assemble the hose to the unit.
While holding the hose at an angle towards the ground, pump the trigger about 30 times. Turn the cleaner on then squeeze the trigger for 30 seconds.
If the water is still not dispensing there may be soap residue bulid-up clogging the nozzle/valve. Try soaking the trigger end in warm water for a couple hours, then repeating the steps above.
If the cleaner is still not dispensing from the hose but dispenses from the unit, a replacement hose may be needed. Follow the link below to order a replacement hose for your cleaner. Search Results
Aug 23, 2014 | Hoover F5826-900 SteamVac Upright Wet...
Bissell instruction manuals
I think you are referring to the stair/upholstery tool. Attach the hose
to the machine...turn the pump and vacuum on and use....liquid is
dispensed when you squeeze the handle on the tool..
Regards.
Dennis
Aug 18, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Cleaner willnot dispense water and vaccum it again. Soap dispense fine. would like a owners manual.
sounds like you have a clog in the waterline, or a pinched hose.
Locate the water line hose, disconnect, and blow through with can of compressed air.
If nothing goes through...you have a blockage/pinch.
Sep 18, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissel proheat no water will dispense
Check all your hoses and make sure that they are not blocked and everything can run freely through your sstem
Apr 25, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Soap/water solution pouring out on floor when trying to use hose & attachments
The attachment hose is torn right where it connects to the motor . And there should be a trigger on the end of the hose right below where it connects to the hand tool.
Oct 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
I need the nylon part that dispenses water when you press the hose trigger, for the stairs and upholsterly tools.
Apr 09, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Can't get water to spray out of the hand tool nozzle
When you attach the main suction hose to the front of the machine, you also have to connect the soultion hose to a valve located on the side of the machine. When the machine is running, take a small screwdriver and depress the centre of this valve. You should get a spray of water out of the valve which will confirm the valve and pump is working. Now, connect the small solution hose, making sure you push it on all the way. When you pull the trigger on the handle of the hose, you should get spray. If it does not, you may have a plugged nozzle sprayer.
Feb 16, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
106 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
