Question about Air Tools & Compressors
When i plug it up, it only hums. i get no real activation. this is a husky air compressor that i bought from home depot about a year ago. its the stand up type. like a fork truck for moving a refrigerator.
    President:
  • 1,167 Answers
Have you got oil in the pump if not take the cover off the motor and see if you can turn the pump by hand if not its seized or if itsa free your motor has problem either compasitor etc take the motor to a shop and get them to check it
Posted on Sep 10, 2009
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    Air compressor cannot spin up with pressure in tank sometimes
    There is an unloader valve and a check valve on the discharge side of the pump. The check valve is not holding and the unloader is not dumping the pressure so the compressor cannot start. Since it is new, you may want to take it back. If not you are going to be replacing parts.
    Mar 10, 2014 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
    I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
    JUNK Home Depot
    Nov 23, 2011 | Garden
    Need Manual for Husky Model 41214 Air Compressor
    You can get the manual for model 41214 from my dropbox area:
    http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
    BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
    http://db.tt/vQycqXIW
    Thanks,K
    Dec 20, 2009 | Air Tools & Compressors
    Husky air compressor/1.5 hp
    Compressors pull a lot of juice that is why they come with a large power cord. If you use a small extension cord with it it will easily pop a breaker. So first check all your breakers. Second thing is check your manual to see if you have a reset switch on you compressor, as most do. It should be a small, red switch (rocker or push button type), located between the pump motor and compressor switch. The third is a long shot, check to see if the bleeder valve is functioning correctly. It will be the small copper tube running from the pump to the switch. Just make sure the small lever is free to move.
    If this fails to resolve the problem then it is probably the main switch itself. That is a warranty issue. If it's out of warranty then your going to have to either repair or replace the switch yourself. Please feel free to ask for help if you need it in latter case.
    Jun 07, 2009 | Air Tools & Compressors
    Wiring a Husky brand compressor from Home Depot.
    hi! there,
    you can use terminal connector like on figures83ba8af.jpg joint connector or lug connector
    this are more convenient to use
    easy to install and has insulated for connection.
    insulated ring terminal connector
    this is also good for connector more safe for circuit breaker suipply.
    go to the nearest hardware or mall
    Apr 20, 2009 | Air Tools & Compressors
    Air Tools & Compressors Logo
    94 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
