Question about Hotpoint Dryers
My dryer comes on and spins, but it is not drying the clothes. What could be wrong?
    Brigadier General:
  • 3,513 Answers
Hi
Check the exhaust pipe in the back is not being crushed. Most dryer manufacturer's require a metal duct from your dryer, but a lot of people who install their dryers themselves use a white vinyl hose. This is not an approved installation and can be dangerous. If you do have a white vinyl flexible hose you should have a professional install solid metal piping. If you already have solid metal piping on the exhaust it might be blocked with lint. This can be a fire hazard, so you should have a professional come in and clean the exhaust duct and the dryer itself. If the exhaust gets blocked the dryer takes longer to dry and can overheat and cause a fire. If you do all those things and the dryer still takes a long time to dry it is possible that a thermostat or the heating element has malfunctioned.In this case, you'll need a repair person to come to your house to fix it.
However you can also check your dryer vent on the outside to see if the air flow is sufficient...you should feel a good flow of air..clear the vent pipe by removing the vent cover..taking a piece of pvc pipe.. taping a wire brush to the pipe ..with the dryer running work the brush around inside the pipe.It will work.
All the best.
Thanks for contacting fixya.com
Posted on Sep 10, 2009
    President:
  • 1,653 Answers
Its most like to be the thermostat, temp sensor or the heating element is broken.
2 Suggested Answers
  • 6 Answers
SOURCE: LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Posted on Dec 28, 2008
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
How to more dry after completed washing
A washing machine does not really dry clothes. All it does is that it helps remove most but not all water from the clothes by spinning the clothes at a very high speed and the water comes out because of centrifugal force.
To further dry the clothes, you need to buy a clothes dryer. This machine has a heater inside that actually dries the clothes while keep it spinning at a slow speed.
Usually the company that made your washing machine will also have a dryer in the product portfolio.
Hope that helps
Feb 22, 2015 | Washing Machines
My dryer is Tcm570 it started leaking water on the floor while clothes are drying, then not drying after circulation. But if I try to put it on now it turns all the power in the house off. What's
There are a lot of parts to this problem: First don't plug it in again or try to restart it...yet, Make sure before you reset the circuit breaker that you unplug the dryer. So now your home should be fine! The dryer is another story... I have answered this problem for others and with other dryers... Please focus on your washer, there should be very little water that remains in your clothes after the wash cycle and the clothes should Definitely not be dripping. Check to see that your spin cycle is working and if necessary run it through the spin cycle again. You may be overloading the washer. Back to the dryer...NO water should EVER drip from a dryer! If you do not wish to call a service person I would wait about 1 1/2 weeks for the dryer to dry itself and give the dryer another try after that and set it for Air dry only (no heat) if you don't have a problem at that point then stop the dryer and set it for a low heat cycle and try again. I think at that point you should be OK? If you do have problems.. you will have to call in a service person. But please remember clothes should be quite dry coming from the washer before going into the dryer.
Jan 12, 2013 | Dryers
My drying is running and spinning properly but no heat is coming out to dry the clothes, any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
My tumble dryer doesn't dry the clothes
Check your breaker - a dryer will spin at 120 volts but needs the full 240 volts to dry. If that's not it, check your vent going outside the house and the hose coming from dryer. If its clogged, that's your problem. If not, you'll have a heating element issue which involves two separate fuses (and the element). Its best to hire someone if it gets to that point. Good luck...
Nov 16, 2009 | Dryers
My tumble dryer is spinning and everything but my clothes are coming out cold and half dry, how can i solve this?
Clean the vent and make sure you have good air flow to the outside . You can disconnect the vent from the dryer and dry a load of clothes . Comes out dry , vent is the problem .
Jul 30, 2009 | Dryers
Whirlpool dryer won't dry
If your dryer spins and heats properly and the clothes don't dry, then very simply put, the moist air is not being taken away. If your drying temp is adequate, then the problem is with the exhaust. Go to where the air is being exhausted outside your home, if working properly, when you put your hand on the air coming out, it should get damp very quickly. And ALWAYS clean the lint trap after every load!!!!
Jun 21, 2009 | Dryers
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
Dryers Logo
63 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
