Question about Frigidaire FEF366 Electric Kitchen Range
Glass top burned through
I had water oil over and it burned all the way through the glass. Can it be repaired.
    President:
  • 704 Answers
Yes, the top is available as a replacement part. You can check the link below to narrow down your exact range model number, as there are about 51 variations for this model series (you'll need the letters/numbers at the end of the FEF366 to zero in on the parts list).
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=N9LEW3Qt6z2wIPtmEnod-w**.shcapp3106?modelNumber=+FEF366+&pop=flush
The cost for a new glass top is around $220 plus S&H (+/-). It is a relatively straightforward removal and replacement process, where all you need to do is disconnect the range from the power plug and pull it out from your counter, etc. and remove the rear fastening screws that hold the backsplash onto the top surface frame and exchange it for the replacement top.
Just be carefull when removing the old, broken top, as the glass will likely shatter more as you remove the frame. Wear safety glasses and work gloves to prevent getting cut, etc. All you need are simple hand tools to do the repair.
I always like to state that you might want to consider the age of the stove before committing a couple of hundred bucks to buying a repair part, but you have to decide if you're looking to keep and repair your stove, or whether you want to get a new one - the decision is yours to consider and make. Just a little FYI.
Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
Why do the polo 2004 headlights turn white I had it replaced x2 already? Is this a bad factory fault?
after market headlights don't last as long as factory, the white color tells me something cracked the glass causing the gas inside to escape and the filament to burn up.. water leaking into the housing?, or have you touched the glass with you fingers?, oil from your skin will also crack the glass at operating temperature.
Mar 19, 2015 | Cars & Trucks
I have a Maytag glass top range. Almost from the first use, a spot appeared on a back burner, looked like water under the glass; It has steadily grown to nearly half the burner size. On a big front...
The problem you have is most likely due to a defect in the glass top. Contact Maytag and demand a new top. The defect can cause the top to burst and cause serious injury. You should contact maytag in writing, with a copy to the United States Consumer Product Safety Commission.
Feb 10, 2011 | Maytag Kitchen Ranges
1994 suzuki 750 . do i check oil through looking glass with motor running or off ?
Balance the bike to a level position while looking at the oil glass, with the engine off. Bottom of glass is low, top of glass is full, no oil in glass, top it off, not quite a qt. Use high quality motor cycle full synthetic 5w 30. Hope this helps.
Aug 22, 2010 | 1994 Suzuki GSX-R 750 WR
Discoloration on ceramic top
Hi- High temps make for tricky maintenance of glass or ceramic tops. The heat element must pass its heat energy through the glass or ceramic and into the pan. Water droplets will steam away, while a spatter of oil or even a few grains of sugar will melt and burn to a tough film of carbon on the surface. The obvious preventitive measures of checking pan bottoms thoroughly before contact with clean (yes- very clean) cooktop surface mean most spots may be small, they can be annoying to look at and tough to remove. My best cleaning results for these spots came from using a VERY small amount of OVEN cleaner (use gloves) on a paper towel placed on spot for a few minutes. A clean, new razor blade may be used to scrape off film. Hope this helps. - Thanks- ED
Feb 25, 2010 | Kitchen Ranges
I burned my glass lid. Left the gas burner on and
It depends on the age of your range. Is this the glass cook-top that is burned or the glass door of the oven? Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST Monday through Saturday fr all your appliance repairs, parts & accessories.
We look forward to working with you and wish you Happy New Year! Thanks, Ella
Jan 09, 2010 | Kitchen Ranges
Kawasaki 2006 KX450F Oil capacity I'm doing my first oil change on this machine after picking it up secondhand. Engine says .98litre with filter out, Manual says the same, however manual also says set oil...
Fill to the site glass. Anywhere from middle of the glass to just below the top of the glass. The engineers put the glass there for a reason. Typographic errors do come to light at times.
Top rating on the answer! Thanks. :)
May 19, 2009 | 2006 kawasaki KX 450 F
Burnt sugar caramelized on a Jenn-Aire glass cook top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuuf really works
Mar 14, 2009 | Jenn-Air JJW8230D Electric Double Oven
White glass cooktop hard to clean
First thing I thought of was that your pots have oil or build-up of some kind on the bottom. Try cleaning them with a solvent of some kind. As an experiment, try using a pyrex pot to see if that makes a difference. As for cleaning the cook top, I use a vinegar and water solution with a soft cloth or very low abrasive scrubber as you can scratch the glass quite easily on some kinds.
Sep 17, 2017 | Jenn-Air JES9860 Electric Kitchen Range
Drain and change oil
I can't tell you all the particulars from the limited amount of pictures of your bike. -Remove the oil drain bolt on the bottom of the crankcase (the universal bolt size for bikes use a 17mm wrench). -Drain the oil (remember to recycle). -Re-install the drain bolt with a new sealing washer if necessary. -The oil fill cap should be some where on the top of the crankcase. About 1 or 25mm in diameter with a raised tab for turning. -Fill with recommended oil. -There are 2 ways to check oil level on dirt bikes: 1) Oil level check bolt. On the right side cover. 2) Oil level site glass. A 1 round piece of glass on the side of the crankcase. Usually by the kick start & R brake lever. -Always check the oil level with the bike upright (as if you were sitting on it). -Check bolt - fill with oil slowly until oil comes out of the check bolt and re-install it. -Sight glass - fill with oil to cover 3/4 of the sight glass. -Remember to hold the bike upright when adding oil.,
Nov 10, 2008 | 2008 Derbi Senda Baja 125 R
Broken glass cook top
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
Jun 26, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Frigidaire FEF366 Electric Kitchen Range Logo
253 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
