Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
What is DTV??
In the section at the side of the screen after you press the button you get tv,dtv, av1,av2,av3,av4&av5 what do'se dtv mean?
  • Tomas Kotlarik Oct 06, 2013
    in the right corner(top) i always have ''ADV'' written with fairy font, how can i delete it?
  • 189 Answers
HELLO
Basically DTV means Digital TeleVision. You select this to get your viewing through your aerial (Freeview) providing you have it tuned in of course. That's all it means.
Posted on Sep 10, 2009
Testimonial: "thanks thats what I thought but when selected the screen goes blank so how is is set up please? "
  • Tony A Sep 13, 2009
    HELLO AGAIN
    You won't get any channels if it is not tuned it, or it may be your aerial is not suitable (even so,you would probably still get something).
    I am not too familiar with the tuning process of this particular TV, but if you press MENU then it should give you the option to tune in the freeview. But make sure you are on DTV to do this and tell the TV to scan for all digital channels.
    That is about as much as I can help you on this one, maybe someone reading this has other ideas? Why not just have a go anyway?
    ALL THE BEST! (:-)
What does AV1 mean on a SAM*TRON TV mean? How do I get rid of it?
av 1 is the source input for the tv
there should be av 2, 3 4 etc and each one isa for a different input item
for example av1 is for the tv -aerial , av2 may be dvd input , av3 may be x box, av4 home theater
how to get rid of it . click on exit or ok
Sep 30, 2016 | Televison & Video
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
The television keeps tripping from av1 channel to tv/dtv channel
Unplug av1 and see if it stays on dtv. If it does then plug the composite cables into av2. If it switches back to av2, you have a bad main board.
Nov 16, 2011 | Televison & Video
How do I switch to AV3 , AV2 And AV1 functionon the sony Bravia 40 inch HDTV
All you need to do is press the TV/VIDEO button in the top left corner of your remote. Each time you press, it will cycle through the connected external inputs, e.g. AV1, AV2, etc.
Hope this helps.
BElectric
Nov 23, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Remote codes
the 4220 does have SAT code 1377 on board, and will work with the following Directv sat receiver models: D10, D11, R15, H10, H20, and HR20.
Try code: SAT1377
What address is the D10 set to, DTV (00001) or AV1/AV2 (00002)? SAT code 1377 is for receivers set to white remote native code 00001.
to blink back the code on the white remote:
1. dtv
2. press and hold MUTE & SELECT for two blinks
3. enter 9-9-0
4. press #1 key, it won't blink because the numeral is zero
5. press #2 key, same as a above, zero blinks
6. press #3 key, zero blinks
7, press #4 key, zero blinks
8. press #5 key, this should be 1 or 2 or 3 blinks
Mar 31, 2010 | One For All URC4220 Remote Control
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
BLANK TV
hi, what you need to do is find the source button or av button on your remote control as it sounds like its changed source this causing your problem. As you probably know your telly has many inputs for dvd vcr cable or sky but these plug into one of the inputs in the back of telly. Usually the problem is just that your on the wrong input channel like av1 instead of av2 or rgb their are many inputs so you might need to press this button 2 or 3 times till you get the right channel, i dont mean 1 to 9 channels i mean input channel like rf input or av input. This depends on what your getting the signal from if its cable and its plugged in via scart lead then it will be an av input but you might have av1 av2 av3 av4 this depends on your telly.
If your still having problems then give me a shout back ok best to check all the leads are in the telly correct as this will cause the problem your having ok.
Let me know how you get on ok or if you need further help
May 14, 2008 | Philips 32PFL5322D Television
Banding on LCD TV
you need a new motherboard
Dec 09, 2007 | Televison & Video
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
260 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
