Question about Car Audio & Video
Can I replace a motorized antenna with a non-motorized simple antenna and if so how?
How to replace factory bose radio on 2000 cadillac seville
buy the adaptor kit sold in all autostores.
then plug it in to the new radio.
even walmart has em.
only sticky wicket is the antenna's on some cars use non standard connections. (std, is a simple round metal plug ) look first
May 06, 2014 | Cars & Trucks
92 oldsmobile cutlass antenna motor broken
Replace the antenna assy
Doubt any dealer has one, going
back 7 years, let alone 21 years
Olds is out of business also
Salvage Yard or On Line or replace
with a non electric antenna
Apr 05, 2013 | 1991 Oldsmobile Cutlass Ciera
1993 T100--Unplug antenna motor
Find access to where the antenna motor is, and visually inspect/trace what kind of electrical connection there is going to it. It may be a simple unplugging of two connectors. I am suspecting that the antenna motor and the radio share the same fuse, as the power from the radio passes thru to the antenna motor when the radio gets turned on. So, can't just pull the fuse. But if there is a fuse JUST for the antenna, then pull it out.
Apr 10, 2010 | 1998 Toyota T100
My antenna does not go down anymore. Is it
Do you still hear the antenna motor, as if it is trying to goo up & down as usual?
If so, then its likely your antenna is just sticking and needs some graphite lubricant. Ask for it at your local autoparts store..pretty simple to use.
If you don't hear the motor I'd suggest you check the fuses etc. If all is okay there it likely needs replaced.
Feb 23, 2010 | 1996 Nissan Maxima
Antenna on 2005 sonata does not raise up when turning radio on
Keep it simple first, check the fuses. If they are good check to see if motor is getting power. May have a bad relay.
Sep 22, 2009 | Hyundai Motor 2002 Sonata
Power antenna motor will not shut off
I assume that the power antenna unit is an original equipment unit, if so.
1. Does it run for about a minute then stop? If this is the case, your antenna shaft needs to be replaced. This is a very simple procedure that your local radio install shop can do for you in about 20 minutes.
2. If the motor never shuts off as long as the key is on, you probably have a defective relay on the antenna motor. At this point you need to replace the entire unit. A job that can be a bit pricey because of the price of the unit itself. A cheeper fix is to replace the power antenna with a manually telescopic unit, (no motor), or a fixed unit, (doesn't go down). If you opt for the latter, remember to unscrew or lower the antenna in automatic car washes!
Jul 07, 2009 | 1984 Cadillac Eldorado
97 4Runner broken antenna; want to replace it with non-power antenna
You will just need to get a antenna that will fit your vehicle try a local stereo shop and wire it in.
Aug 22, 2008 | 1997 Toyota 4Runner
Replace power antenna with regular antenna
If the antenna is making a noise (the motor running) like it is trying to go up, but it is not doing so there is a chance that your antenna gearing strip is broken! It cost about $23 to get a new part from a dealership, and takes about 2 min to fix. When you get a new antenna with gearing strip to replace the old one all you need to do is unscrew the cap around the antenna and then turn the radio on. this will cause the antenna to come out. you will need to do the revers to put the new one in.
However, this becomes a problem if the gearing strip is broken. if so you will have to take the motor out and get the remaining part out before inserting the new one. the motor is located under the wheelwell of the passager side tire in the front of the vehicle. pretty easy to do if you have any common sense, but will probably take you an hour to complete this part of the fix.
Now, if you are wanting to replace the entire antenna with a non-motorized antenna with one that come on an old vehicle this is totally doa ble, but will take much more time and more skills on how to wire different components together. by preforming this task you will have to run a new antenna line from the antenna to the back of the radio. If it sounds like i am talking a foreign language than just take it someone to get it done! or find that cute opposite *** who knows what they are doing and have them do it for you. But dont listen to them when they tell you sure they know what they are doing, if they say it will take no more than 15 min or a couple of hours because then, They Do Not know what they are doing!
Aug 03, 2008 | 1994 Toyota 4Runner
Car Audio & Video Logo
183 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
