Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Drum out of balance
It looks as if the shock absorber on the right rear is defective. The drum is leaning to that side. The drum will no longer spin at high speed smoothly.
  • 396 Answers
The top panel should lift back on hinges after you free the front clips. Make sure you do not have to loosen any screws under the lid as some models are different. You can use a small wood wedge to gently pry up the top panel so you do not scratch the enamel paint. Once you lift the panel back you can inspect the arms which support the tub and easily replace the defective support or rubber shock absorber.
Posted on Sep 10, 2009
My drum is loose and won't spin even by hand
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Sep 21, 2014 | Whirlpool Washing Machines
After 23 years of good service the drum has fallen off at one side. Is it worth fixing or buy a new one?
HAS SHOCK ABSORBERS WHEN THEY GO BAD ONE SIDE CAN LEAN ALSO CHECK FOR BAD OR LOOSE BALANCE WEIGHT. LOCATED NEAR THE MOTOR.
Jan 28, 2014 | Asko W6221 Front Load Washer
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Why does washing machine drum bounce around?
i had same problem but i was terrible at balancing loads......also being a male i tend to overload and this also did not help.....under normal loads the shocks get a big work out going in alternating directions and with full loads......if it bounes on spin it is poor balancing,if it bounces and bangs while washing i would think shocks or overloaded
Mar 03, 2013 | Hoover Washing Machines
Drum suspension failure
The suspension spring of the drum has come off and this means that the drum is hanging off the center.
The drum is hung with spring and shock absorbers and if one side has come off it will be off balanced. The springs are hung from the corners of the BODY FRAME. Check this out, replace spring if the end had broken or also you can use a good plier to extend the spring head to be clipped.( if broken)
Dec 30, 2012 | Asko WL6532XXL Washer
With some loads ie towels, the drum moves about so much that it bangs on the inside of the casing and the whole machine tries to walk around the room.
there are some "shock absorbtion" devices inside that may be defective...you can try to remove the top lid and look down on either side of the drum...the shock absorbers look like cylinders and are mounted at the bottom of the drum..one on either side ....you should also have two springs at the top..make sure these are in place...if the shock devices are defective(usually they break at the mounting side on the floor pan of the washer) you can try getting new ones at applianceparts.com.
this website has blow up diagrams to aid in helping you get the right parts
Jun 11, 2011 | Hotpoint WMA58 Front Load Washer
Mywasher is off balance during spin cycle
Posssible shifting in the suspension of the drum or the failure of the shock absorbers. Look under the drum for the suspension, the counter weights and the dampers/shocks.
Replace teh dampers if they look sloggy, rectify any alignment of mountings and possible failrue of the drum bearings should also be checked.
Do not try to over load the drum and when washing large items like sheets take care to fold over.
Aug 21, 2010 | Maytag Legacy Series Top Load Washer
I have a Kenmore Washer Model 23832. During the
YES> There are shocks and springs. The springs hold it up and control motion and the shocks absorb the movement and stabilize the basket. Sounds like you may have broken shock.
Feb 17, 2010 | Washing Machines
Tub wobbles terrably in spin mode
Try lifting the inner drum to check if there is any movement between the inner and outer drums, also turn the drum and listen for any grinding or scraping sound from the rear of the drum. Its possible that your bearings have gone out & need to be replaced. The job is far from easy.
Mar 16, 2008 | Kenmore 98702 Stacked Washer/Dryer
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
219 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
