Hotpoint 24 in. HDA3400G Built-in Dishwasher
Problem for Hotpoint 24 in. HDA3400G Built-in Dishwasher
Dishwasher doesn't drain
By allaboutsept on Sep 10, 2009
This dishwasher will drain sometimes but not always all the way. It seems after running a cycle it will look drained, but after a few hours it fills the bottom with water. The drain hose is clear, as is all the traps and drains under the sink. The screens aren't plugged but I haven't taken anything else apart yet. Any ideas?
Thanks
Solution #1
posted on Sep 10, 2009
Somewhat Helpful)
57 varieties
Rank: Guru
Rating: 88%, 530 votes
The drain motor might be worn so it still pumps out fairly well but will let wtare back in once it stops pumping. It may also have something stuck in it so it ot is worth removing and cleaning through with a good degreasing cleaner.
Was this helpful?
Yes
No
Popular Solutions for Hotpoint 24 in. HDA3400G
Questions and Unsolved Problems for Hotpoint 24 in. HDA3400G
Do you recommend Hotpoint 24 in. HDA3400G Built-in Dishwasher?
Answer
Answer
clip broken off detergent loader container, container will not clip shut.
Answer
how do i drain the macerator connected to my toilet, it has broken and needs to be changed. this... (More)
Answer
the solenoid for the waist water dump valve has over heated and melted twice. valve not the problem.... (More)
Answer
My dishwasher does not drain. I've pulled off the main top screen. What next? How do I pull off the... (More)
Answer
Machine went through first light wash and then stops on the second light(spray) and beeps and won't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. HDA3400G...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
