Question about John Deere Tractor 1020, 1520, 1530, ITJD37
I have a 1520 tractor where the starter was staying engaged even after the key was in the off position. This eventually caused the battery ground terminal to burn off and the battery to discharge. Any thoughts? Bad starter? or what?
  • 61 Answers
Starter solenoid need to be replaced, also check all ground wire connections for corrosion and clean them
Posted on Sep 10, 2009
Craftsman riding mower starter will spin but not engage
The keys are not dropping in the clutch fan. Lightly tap with hammer before attempting to start. Will need to replace eventually.
Dec 16, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
What would cause no spark when the starter motor is engaged and spark when the the key is the run position.
It's the safety switch under your seat. Did you sit on the tractor when you tried to start it? If you didn't the spark would have been shorted. GOOD LUCK FRIEND.
Sep 17, 2014 | Garden
My 155c John Deere will not start! Brand new charged battery....I turn the key...nothing(no clicking either). When bypassing it to cellinoid, it starts right up. When I shut off the mower, I have to...
Usually when the key is turned to start position the starter soleniod engages thus applying power to the starter. There are three possible causes to your problem . (1) Check for 12vdc at the terminal on the soleniod when the key is turned to start position, if there is 12vdc at the terminal then the key switch is good. (2) loose or bad cable connection at the soleniod, check connections. (3) bad soleniod -- replace it. generally you will hear a click from the soleniod when the key is turned to start position. Also be sure to check that ALL safety switches are engaged. You may need someone to sit in the drivers seat so that switch will be "made" / engaged. Park Brake is set, mowing blades are "NOT " being engaged, on some mowers if the transmission is in reverse ,even tho the brake is set the mower will not start.
Nov 10, 2013 | Garden
1997 Lexus SC300. 113,000 miles. Starter stays engaged and keeps cranking motor with ignition off and key out of ignition. Had to pull battery cable to disengage starter. When battery cable is reattached...
You most likely have a short in the wiring to the starter.
Last time I saw something like that a vehicle's exhaust headers created heat which eventually melted the wire's insulation and several of the wires were exposed and shorting on each other and the ground of the vehicle. If possible, get the car on a lift and inspect your starters wiring....
Hope this helps...
Jun 17, 2011 | Lexus SC 300 Cars & Trucks
Makes clicking noise when we turn key we replaced seloniod and now we cant get nothing out of it it wont click and it wont turn over what did we do wrong weve did it before and it worked fine
check all electrical connections between battery and starter both positive and ground, also check battery condition and charge, If the seloniod has three posts on it jump the positive side of the battery where it connects to selonoid across to the small center terminal of the selonoid and this will cause the electromagnetic unit to to send power to the starter, if this proves unsuccessfull, use a jumper cable to jump the battery 12v power directly to the large electrical terminal on the starter itself, this will spin the starter motor but might not engage the gear drive
Jan 08, 2011 | Mtd Garden
Cant get the mower to turn over. Have good battery voltage and the relay clicks. there is 12+ volts to the starter when I engage the key. How do I check the starter/solenoid further? or is it clearly a bad...
get a wire that goes to the positive terminal on the battery and touch it to the bolt on the starter and see if it works then. if not, the starter could be bad, screw the plastic gear back up til it engages in the flywheel on the engine and hand turn the lawnmower with the starter gear engages to loosen it up then try
Aug 02, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My car wants to keep starting even after turning the key off
solenoid may be sticking. Have someone start the car, if it sticks tap the solenoid with screw driver handle. If that stops the starter, replace the solenoid. If it were me, I wouldn't bother testing it and just replace solenoid.
May 09, 2010 | 1989 Ford Crown Victoria
My mower wont start...i replaced the battery and it just clicks
Have a friend jump start the mower while you a seated on it. Turn the key to the "on" position. Connect the black jumper cable from a known good battery to a good ground on the mower and the red cable directly to the electrical connection of the starter. If the starter does not engage, it is faulty.
Apr 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
2000 dodge intrepid won't start
check cables to battery.if battery is 5years or older replace.
a bad ground cable and a weak battery will cause the starter to do as stated.
Feb 07, 2009 | 1999 Dodge Intrepid
The starter relay on the fender is the most common cause of this condition. ,It is on passenger side feder in the engine compartment, it is round and the positive cable of the battery goes to it,
Nov 12, 2008 | 1987 Ford Ranger
John Deere Tractor 1020, 1520, 1530, ITJD37 Logo
299 people viewed this question
Top John Deere Toys Experts
Jim Goldsmith
Jim Goldsmith
john h
Charles T Nevin
Charles T Nevin
Are you a John Deere Toy Expert? Answer questions, earn points and help others
