Question about KitchenAid KEMC378 Electric Double Oven
Power failure KitchenAid Superba Micro/Convect built in oven
We just had a brief power failure and the display on the oven is all lit up and I can't clear it.
  • 12 Answers
SOURCE: How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy. http://www.bedbathandbeyond.com/product.asp?order_num=-1&SKU=10161738
Or you could go for a digital one with a probe.
Posted on May 21, 2009
  • 6 Answers
SOURCE: KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Posted on Jun 30, 2009
SOURCE: Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Posted on Jul 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchenaid Superba electric convection oven not preheating right
Your temperature sensor is failing. Replace the temp sensor.
Posted on Jul 21, 2009
MNfisherman
  • 11896 Answers
SOURCE: my kitchenaid superba oven model
This is a faulty oven temp sensor
should be a schematic in the oven when you take it apart. You can get the part at daysappliance or partselect . com
Posted on Sep 24, 2010
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
Aug 25, 2016 | KitchenAid Architect II Superba EQ Series...
Kitchenaid Superba 27 built-in Microwave/Oven
Disconnect it from power outlet for 30 minutes to hard reset the owen. It may be a faulty control panel or the fan thermistore switch.
Apr 02, 2008 | KitchenAid 27 in. Built-in...
Superba model: YKEBS208DB3 electric sove shows code PF. what does this mean?
PF stands for power failure, just hit cancel and reset clock.
Good Luck, I hope this helped.
Nov 27, 2013 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid superba oven manual
Power failure. Usually comes on when the power to the oven has been interrupted Setting the clock or turning on the bake or broil will clear it..
Nov 11, 2013 | Ovens
Kitchenaid Superba walloven/microwave - problem with big oven.
I lost power and had the same problem. 177 degrees and ERR whenever I tried to change it. Reading the manual, I noticed that it was showing the degree symbol instead of F. When you hold down the broil/maxi/econo button for five seconds, it changes to F and then it worked perfectly. Makes no sense, but worked without any repairs needed.
May 12, 2010 | KitchenAid Ovens
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Apr 08, 2009 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
KitchenAid KEMC378 Electric Double Oven Logo
163 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
