Question about Philips Televison & Video
Philips tv, A63AFW36X, when you press power button red (power on indicator light) comes on momentarily then you can here something trip and light goes out, picture never comes on. is there anything I can do to repair...
  • 10 Answers
SOURCE: strawberru shortcake tv turns on then right back off
Sounds like the power supply may be going out, or check and see if there is a circuit breaker button on the back. Otherwise there may e a blown fuse that is internal. Don't open the back unless you have training on what is safe to touch as the picture tube can maintain a HUGE electrical charge that can stop your heart if you accidently touch the wrong thing. Sounds like a weak power supply tho. Jay
Posted on Jan 21, 2008
SOURCE: Wii Power, Wii Goes Dead when I press Power or Eject Button or Remote Power Button. Is THIS AN INTERNAL DAMAGE
According to Nintendo u can try this. 1. push the reset button and if that doesn't work unplug all cords and memory cards (including sd) from wii and unplug av from the wii and the outlet in wall. Wait 2-3 min and then plug it back in. Thats as far as i got because that fixed my problem hope this helps someone!!!
Posted on Jun 18, 2008
  • 848 Answers
SOURCE: red light blinking on power
this all problem may exist in your tv
1. High voltage problem/ deflection circuit problem.
2. Shorted picture tubes.
3. Problem in the vertical deflection circuit.
4. Problem in the audio ouput circuit.
5. Problem in the convergence circuit.
6. Problem in the power supply regulation.
7. Problem in the portect circuit.
8. The common high voltage arcing that Toshiba sets do at the picture tube.
so for getting pictures gently tap on the side of tv if it works then there may be some loose connection you can fix it by soldering
Posted on Jun 22, 2008
SOURCE: I have a Philips flat
Hi its ok now I called out a repair guy.
Thanks Sonny
Posted on Aug 05, 2008
SOURCE: Sharp tv standby button wont switch on
have the same problem .please help.
Posted on Aug 31, 2008
Dvd playing problems
your tv has a set up menu, make sure that the tv can see the new device, also your remote for the tv should have an input button, scroll through them till you find it.
May 01, 2017 | Televison & Video
Philips model 19ps35s321 univerial remote code for tv
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917 useful or nor?
May 02, 2011 | Philips Televison & Video
Need the universal remote code for the phillips dfr 1600
Hello
Three digit codes for Philips are
PHILIPS Codes: 003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
philips magnavox are:
PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
Four digit codes for philips are:
PHILIPS ........... 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
PHILIPS-MAGNAVOX ..... 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
May 02, 2011 | Audio Players & Recorders
What is the code for the philips remote for a symphonic tv
Hello
There is no specific code list given to this Philips remote control model. Yet you can find out the stored code of your device, whichever it may be, by the following method.
Turn on the device (TV, VCR, etc.) to be controlled.
indicator remains on, then release SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((or POWER or
PLAY (VCR only)) repeatedly until the device to be
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
OK.
Feb 23, 2011 | Philips SRU2103S-27 Remote Control
Remote code for the tv
Hello
One amoung this will be your TVs' code.
Three digit remote codes for Philips Magnavox are:-
002/ 009/ 109/ 118/ 209/ 309/ 402/ 408/ 502/ 508/ 510/ 807/ 914/ 917/ 020/ 422/ 919/ 922/ 183/ 184/ 208/ 213
Four digit remote code for Philips Magnavox are:-
0062 0204 0207 0183 0226 0288 0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
NB: Switch OFF and then switch ON your tv with its front panel power switch [NOT BY THE REMOTE CONTROL HANSET]; each time before trying an other code.
Proceedings:-
Direct Code Entry
OK.
Dec 25, 2010 | Philips Magnavox 27MS343S 27" TV
Power button flashes red. TV comes on momentarily
this is a inverter board defective. please change-it
Oct 31, 2009 | Panasonic TH37PX60 37 in. Plasma...
Cannot swtich on the tv
I think you mean ' switch ' and ' only the red light ' ( power ) comes on.
It could be an internal trip on your tv set that needs looking at by a tv engineer ( normally parts required ) or if you have a tv with a ' factory settings button ' on it ( normally on the side or top if it's a flat screen tv ) press and hold for 10 seconds then the intial ' tv setup ' will appear on the screen ; after that, just follow the guide.
Hope this helps.
Jul 24, 2009 | Philips FTR-9964 Tuner/Receiver for Plasma
I HAVE LOST THE MANAUAL FOR MY PHILIPS MAGNAVOX UNIVERSAL REMOTE
You don't need the whole manual for the Philips Magnavox remote fortunately.
If you want to reprogram it for the Apex TV, follow my directions exactly.
  1. Hold down the Code Search button (on the remote) until the light on it turns red and stays red.
  2. Let go of the Code Search button.
  3. Make sure to switch modes at this point to which device you want to program, I'm going to assume TV Mode since your post says "Apex TV." If you need help with Apex DVD codes, I can answer that one too :)
  4. As you Press the mode button and release it, the light should blink for a bit, so keep your eye on it because after it's done blinking it'll stay red.
  5. At this point the remote want's you to press a sequence of numbers also known as Code[s] or Code Entries. Either way these are what are in a table inside the manual that you lost.
  6. I'm going to give you two codes in case one doesn't work: 044 and 335 (one of those hopefully will work)
  7. If the code worked you'll know right away because the light will get mad and start blinking again, otherwise if it DID work, it'll just turn off (the light will anyway).
  8. That's it, I reccomend you test out your remote with the TV now and make it everything works. If something doesn't, try the other code. If it still doesn't work right, I'll give you some more codes.
Hope that helped,
-Cheers-
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
3. Enter the 3 digit code from the code tables. Note:
4. With your device on, press CHANNEL Up. If the
equipment, try one of the other codes for your
brand.
APEX 044
Mar 21, 2009 | Philips Televison & Video
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Televison & Video Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
