Question about Diesel Garden
The shaft broke on my '93 kubota mower deck.. ''GF1800'' I replaced the shaft but am having hell getting both the pto shaft and the blade drive shaft gears to go together... ''Im running out of room to work'' Any tricks of the trade to help me out ????
  • 69 Answers
SOURCE: I can not get my mower deck to turn when I pull
Your switch could be bad, or the voltage needed to turn on the PTO may not be up to par, or you may have a safety switch that won't let you start the PTO. I'd start with the safety switches.
Posted on May 11, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
  • 61 Answers
SOURCE: I have a scotts (made
sounds like safety switch
Posted on Sep 06, 2009
  • 133 Answers
SOURCE: need to replace drive belt on cutting deck and
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from coming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Oct 24, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
Kubota zd28 mower was running fine put away but now PTO wont engage.
if your saying that pto wont do anything , that's either an electrical short or a broken belt , in rare cases the clutches go too , now if your saying the pto engauges and stalls the engine or makes horrible noises , then that's a bearing , im betting the deck shaft bearings are in need of some serious grease work
Mar 04, 2017 | Kubota Garden
PTO turns without mower shaft inserted. Mower blades turn when rotating shaft by hand. Slide shaft back into PTO and nothing is turning. Belts on mower deck look ok.
Sounds like your magnetic clutch is not fully engaged or slipping and cannot handle the load of the mower deck..try this...Using a good pair of snug fitting gloves..with the engine in its lowest idle position and the shaft out of the clutch turn on the clutch..now carefully see if you can manually stall ( make the clutch slip) if it does sip or stall it needs replaced.just be careful....good luck..
Jul 29, 2015 | Garden
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Apr 23, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Why gt 2554 pto belt keeps breaking
bad spindles in deck get the deck up get pair of glove jerk the hell everyvery one those blades replace spindles that move around
Sep 03, 2014 | Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Blade hit the ground and bent. Now getting a growling sound from blade bearing housings and mower stalls after five minutes or so.I did replace the blades...
I have a feeling that the bearings were damaged when they hit. The new blades are ok, but the bearings are growling and I don't know what is causing the engine to shut off. I would pull the deck off, check out the bearings, replace them if needed, just wobble the blade back and forth, it shouldn't move, should be tight, Take off the belt and spin the blade by hand, and see if it growls. It could be the drive pulley bearings that went, check them out too. hope this helps.
Apr 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Garden Logo
55 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Ted Maxwell
Are you a Diesel Garden Expert? Answer questions, earn points and help others
