Question about Baby Gear
Maxi Cosi Tobi straps locked
I can't loosen the straps on my Maxi Cosi Tobi child seat. I've tried pulling the socket all the way forward and it doen't loosen them. What else can I try? I can't fit my son in it now!!
Hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Posted on Sep 19, 2009
  • 419 Answers
THe most common reason for this is that the straps have twisted. Follow them all the way around and through the seat to see if this is the case. If this is not the case and the carseat is less than 23 months old, I would suggest that you return this to the retailer for assistance in repair.
I hope this helps.
Posted on Sep 14, 2009
Can you re thread straps on maxi cosi tobi?
Hi
Due to the safety implications of this being incorrectly done it should not be attempted at home. The carseat needs to come in for our engineers to re-thread the harness and ensure it is performing as it should be.
Please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab for your enquiry to go through to the customer care team in your country who can provide further assistance.
Apr 05, 2013 | Maxi-Cosi Tobi Car Seat - Jet Black
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Is it possible to buy new covers and straps for this seat?
Replacement fabrics can be ordered via your local Maxi Cosi retailer or direct from the customer services department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 60GBP and if purchased direct there is 3.99GBP p+p
Jun 25, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
How can i make the headress go upto make the carseat bigger??
Good Evening
Take hold of the headrest and lean it forward (toward the front of the carseat) then you can slide it up and down to wherever the harness needs to be for the best fit for your child.
The shoulder straps should be no more than 1 inch above or below the childs shoulders when correctly adjusted.
Jan 04, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How to alter the straps
how to adjust straps in maxi cosi tobi
Jun 16, 2010 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Straps on my maxi cosi tobi car seat is stuck, can't loosen it
Hi, This sounds like either the harness is twisted at the back or inside, or there is a build up of dirt etc that could have fallen through the **** strap area. I would suggest that you go to this link and contact the supplier who will be able to clarify this for you. http://www.maxi-cosi.com/maxicosi/forms/contact.aspx?mode=contact&language=gb-en I hope this helps.
Nov 11, 2009 | Baby Gear
Straps won't loosen on our two month old maxi cosi tobi car seat
I had the same problem yesterday - evntually I found this on Maxi-Cosi's website:
"I am no longer able to lengthen the belts of the Tobi when the buckle is open, they lock, why is this?
This may happen because the belt buckle is not flapped forward enough. If you push it forward manually, it no longer locks and you can loosen the belts."
Worked for me!
Matt
Apr 11, 2009 | Baby Gear
Maxi-Cosi Tobi Straps not working
I guess that you have perhaps solved your problem now but if not, have you seen this?
http://maxicosi.com/tobi/default.aspx
Hope this helps.
Chris
Sep 18, 2008 | Baby Gear
Baby Gear Logo
1,189 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
