Question about Kwikset 907 907-L03 Lifetime Polished Brass Powerbolt Keypad Electronic Dea
Kwikset deadbolt keyless entry
The keypad will unlock the door sometimes and sometimes it won't. I can replace the batteries and sometimes this fixes the problem and sometimes it doesn't. Right now I'm locked out of the room because we can't find the key. Any suggestions?
  • 68 Answers
SOURCE: kwikset keyless entry is backwards
The config terminal is wrong. Take the cover off and move the 2 pin terminal over one pin.
Posted on Mar 23, 2009
  • 963 Answers
SOURCE: i have a kwikset deadbolt
I was searched but was unable to find any information on the model 898 keykess entry set.
I therefore suggest that you call Kwikset's Customer Service; I'm sure they can help you:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625) Fax: 1-800-713-7080
Support Hours: Monday-Saturday
7:30am-4:00pm PST
Closed Sundays and Major Holidays
Posted on Mar 10, 2011
  • 963 Answers
SOURCE: Kwikset keypad deadbolt will not lock or unlock.
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Posted on Apr 18, 2011
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Posted on Sep 30, 2011
  • 963 Answers
SOURCE: Why doesn't the back lights
Installation instructions for the Kwikset 907 link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
This is the link to Weiser Customer Support Page, where you will find the appropriate number for your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Posted on Nov 08, 2011
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Jan 14, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Just installed keyless entry lock. Lock button works fine, enter code and deadbolt only partially retracts. Worked fine the first time, will not completely unlock since. Key works to fully unlock. Tried...
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Oct 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I have a kwikset deadbolt model 898 keyless entry.i need to change pin number on keypad outside
Feb 04, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
Do you know how to reprogram digital code?? kwikset 907 lock
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Jan 06, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Why doesn't the back lights work on my Kwikset 907 Power 1000 Keyless Entry Deadbolt? Are there any other batteries beside the four 1.5 alkaline batteries?
Oct 21, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Won't unlock door and beeps when code is entered
Got in contact with kwikset took out battery pack then put it back in. keypad reset itself.
Dec 28, 2008 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Kwikset 907  907-L03 Lifetime Polished Brass Powerbolt Keypad Electronic Dea Logo
143 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
