Question about iRiver iFP-799 MP3 Player
Getting music off Iriver
Wanted to know if there is any way of getting my music off my Iriver and back to my pc.
Cheers
  • Edd Feb 04, 2009
    I am trying to find the solution to this too. I found a program to get music back off from an iPod, but that's not my problem. (For anyone who's interested in the iPod fix, just search for a free program named iDump.)
  • 4 Answers
Bronte,
When you change your firmware from the "manager" version to e.g. the Firmware v1.85 UMS version, you will no longer need to use the iriver manager software to move mp3's around, you can just drop them on or from your iriver. The disadvantages are that:
1. by upgrading to the UMS version, you will wipe ALL your current music, so it will NOT help you right now, only after you have upgraded to the UMS version and placed mp3's on there again. The iriver will behave like an external thumb-drive, so you can use it on any PC without the iriver manager.
2. The UMS firmware will ONLY run in USB 1.0 speeds, so it will take up to 36 minutes to fill the iriver up with 1 GB of music (or in my case podcasts).
Regards,
Robert Ilbrink
Posted on May 09, 2009
I have just recently purchased a 2nd hand iriver but dont hav a manual for it & wanted to know how do i put files on my iriver, i have tried both music & video & although it says on the...
You can download the E10 manual from the manufacturer's web site at
http://www.iriverinc.com/lounge/loungeView.asp?selectPart=03&findWord=&sno=821&page=1&cateCode=03
Dec 15, 2010 | iRiver E10 Digital Media Player
IRiver H320 won't boot...
format is exactly what you have to do...but this how you do this...plug iriver
to pc..goto my computer see the iriver...click on and copy all software only (hidden also) from iriver and save to temp folder on pc...now format the iriver.......okay....now copy from that temp folder (the iriver software) back to the iriver.....put you audio/video on its like new again...
Jun 03, 2010 | iRiver H320 MP3 Player
I want to learn how to download music to my iriver spinn
You can use Itunes sofware or windows media player software.
But itunes is more user friendly.
Just import everything to the library of itunes .
Then connect your mp3 player then click on it then select synchronise.
ok
cheers
uttam
Jan 13, 2010 | iRiver Spinn MP3 Player
When I press
it's because the iriver doesn't reconize the artist. the artist name, album etc is set in the file's info. you can write that info yourself so the iriver can reconize it. for example I opened Winamp, imported the songs I wanted in my iriver, right clicked on the the first songin my list, selected FILE INFO and went on and completed the artist field myself. did the same to every other song....and now the iriver reconizez the artists.....it takes some time indeed...and I don't know of any other easyer method that works.....but this one surely will. good luck :)
Dec 15, 2009 | iRiver E100 Digital Media Player
E100 not getting detected
I had the same problem and I realized that my power supply had one pin missed in the 20 pin molex, just changed the atx power supply unit and my iriver E100 was detected.
Sep 04, 2009 | iRiver E100 Digital Media Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Lost software
bradders,
question: from your iriver mp3 have you already format it or the files are still inside?
if your reffering old files as files you've accidentally delete from your player. the only way to retrieve the said files is by using a software "filescav" or filescavenger. this software can only retreive files from any removable device if the said device haven't been formated.
but if you only want to get the present files installed in your iriver, i do think that once you connect your iriver to a PC. the PC will search for a newly installed drive which is your player. and once detected you can open the folder of the newly found device and simply copy and paste all the documents and files you want to copy from your mp3 to PC.
note: you can download filescavenger from web free. just type in google bar " filescavenger" and it will show all the possible download site for the said software
cheers,
mark
Jan 16, 2009 | iRiver iFP-395T MP3 Player
Fried MP3 player iHP140. Hi i plugged a 6 volt charger into my 5 volt unit for several hours. the unit became very warm and now doesn't work. Does anybody know is it repairable. is there a fuse , will a...
i sent mine back to a company called avsense they are in california fo 65 bucks i got mine back in perfect working order!!!! you can go to the iriver web site to get all the info
Aug 28, 2007 | iRiver iHP-120 MP3 Player
iRiver iFP-799 MP3 Player Logo
249 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Mohammad Abumuailek
Mohammad Abumuailek
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
