Question about Dell 926 All-In-One InkJet Printer
My printer will not turn on.
I have tried unplugging everything and replugging it back in, tried different outlets, and restarted my computer. What else can I do?
Lexmark x9575 all in one keeps restarting after slecting scan\copy and fax I have un-installed and re-installed the drivers + reset printer to default factory settings - no change
Try to unplug the power adapter from the printer. Then unplug and replug the power cord into the power outlet. Replug the power adapter into the printer. This will help reset the printer. Check if problem continues.
May 31, 2011 | Lexmark X9575 InkJet Printer
HP PCS 2210 all in one printer/FAX.
ok..unplug from power, and let it rest for around 20 min..then unplug from computer, restart and see if you get a menu panel display
May 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
My printer will not turn on it worked yesterday and i've done nothing different. could it be the "brick"?
Check if it's warm or cold. It could be a defective power adapter issue. Unplug and replug the power cord into the power outlet to reset it. Bypass any surge devices or power strips. Replug the power adapter into the printer. The printer should automatically turn on, otherwise press Power button.
If problem continues, then it could be a faulty power adapter problem. I'd suggest you to contact Lexmark technical support for additional assistance.
May 17, 2011 | Lexmark X2500 All-In-One Printer
My lexmark printer is doing everything it's supossed to, but it's NOT printing. There isn't even any paper jammed. what could the problem possibly be?
Try to disconnect your printer from your computer. Then unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reconnect to your computer. Doing this usually fixes minor communication issues. If that doesn't help, try to check and make sure the print spooler service is running on your computer. Refer to this article: How to Restart or Reset the Print Spooler in Windows.
Apr 11, 2011 | Lexmark X2600 InkJet Printer
Hp 5500 keeps saying cannot communicate with computer?
You can try to:
- Turn the printer off then turn it back on - Unplug and replug both ends of the usb cable connecting your printer and computer - Turn off the firewall - Reinstall the printer driver and software - if it still wont work, try a different usb cable
Dec 31, 2010 | HP Photosmart C6180 All-In-One InkJet...
PSC 2210 will not connect to my laptop with USB cable. The cable is fine - I used it with a scanner already today. It ran the other night - however the print cartidges had dried up and needed to be...
Hi, first; lets’ start from scratch. Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. Thanks paul7of9
Jan 13, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP 2210 All-in-One quit right after I made a copy.
I was looking for a manual online but did not find any, you can check your manual on how to reset the printer. They normally have it in the manual and once you reset it, the printer will return to factory settings including releasing the scanning part.
Aug 17, 2009 | HP LaserJet 3055 All-In-One Printer
Printer not communicating with computer
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
HP 5610 Paper Jam Error Won't Clear
http://h10025.www1.hp.com/ewfrf/wc/document?product=79488&lang=en&cc=us&lc=en&dlc=en&docname=c00042573
Dec 18, 2007 | HP PSC 2110 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
