Question about GE JVM1630 Microwave Oven
GE PROFILE PURCHASED 2006 RUNS BUT NO HEAT MICRO/CONV MODEL JEB1095BB
  • 6,784 Answers
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Sep 10, 2009
No heat
If the fan, lites, all work and appears to be running normal but just no heat, chances are its the magnetron that has failed. Sometimes magnetron will make a deeper noise if it has failed
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
Spacemaker (JVM1871SK) 1800 Microwave doesn't microwave
Remove the case and see if you can localize the smell. Likely suspects are a shorted high voltage diode (replace) or a shorted stirrer bearing (replace stirrer)--a fan-like device located within the sheet metal waveguide near where the microwaves enter the cooking cavity. Make sure to have a cup of cold water in the cooking cavity when looking for problems. The problem could also be the high voltage transformer or the high voltage capacitor, but these are more rare problems. There are no radiation problems with the case off, but there are high voltages associated with the magnetron and it's power supply.
Oct 08, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
No heat micro keeps cycling through all programsdemo in cook/bx
My GE doesn't have a Demo mode but say we have a power failure. It won't let me use it until I set the clock.
Try that and see if it helps
May 26, 2009 | GE Profile Spacemaker Over-the-Range...
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
GE PRofile Microwave runs but no heat
This is a sure sign that the magnatron needs replaced ( This is what heats the food!) replace and all will be good again!
PLEASE rate my response to your question
Thank
You!
Jan 10, 2009 | GE JVM1870 Microwave Oven
GE JVM1630 Microwave Oven Logo
130 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
