Question about Philips GoGear HDD6330 MP3 Player
My go gear is not starting nither is it connecting to the pc. my pc recognizes it as a hid device(which describes it as a ROM recovery)
3 Suggested Answers
SOURCE: "firmware problem" no screen
in reading others problems and solutions, I found a posting that led me to a solution to my problem.
Thanks!!!
Posted on Jan 21, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My Philips go gear SA2515/97not
Hi bysvraju...
Try this method...
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
Posted on Sep 15, 2011
My philips go gear SA60XX 8GB player is frozen and when i turn it on, the Go Gear logo comes up but it won't go any further
You can find description about how to repair your player using this link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6045%2F37&dct=FAQ&faqview=1&new_tmpl=1&refdisplay=PI_C35_SA60XX_002&refnr=0063493&scy=US&slg=AEN
If the PC doesn't recognize the device try recovery mode:
Player Recovery
Sometimes, problems still remain even after you reset the player. You need to use the Repair function in the software. Just follow the steps below:
Important: Content stored in the player will be erased after player recovery. We strongly recommend you back up your data before you perform this function.
1. Press and hold the volume plus button (VOL+) and then connect your player to your PC until the Philips Device Manager acknowledges your player and enters the recovery mode.
2. Release the volume-plus button (VOL+) button and then Click on Repair to start the recovery process.
3. Follow the information on the PC screen to disconnect your player when recovery is complete.
I hope this helps you.
Thanks.
gylacz
Aug 09, 2011 | Philips GOGEAR SA6045 MP3 Player
I downloaded files on my 8gb philips go gear SA52xx product connecting it to a pc and when i unplug the USB connection of my device after everything it has since then frozen and refusing to work even...
Hi leefordnarte,
You can find a lot of valuable resources on the Philips Support Site...I am not sure which specific model you have, but the Product Support Page for the SA5285/37 can be found here:
http://ow.ly/5XLe9
For the issue you described, I would attempt a Repair/Recovery - this process will restore your player to factory settings, as well as update the firmware in the process.
Try the Philips Device Manager software (found on the support site www.philips.com/support if you do not have your original software disc):
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
Hope this helps - if so, let me know by rating this solution. If you have any additional questions or need assistance, you can reach Consumer Care at 1-888-744-5477.
Aug 08, 2011 | Philips Audio Players & Recorders
The screen of philips mp3 go gear spark is blanked out and doesnt start
Hi sheetalsrsh0,
For more information on the Philips GoGear SA5125/37, including FAQ's, manuals, and software, visit the Support Site:
http://ow.ly/5RdZo
Performing a Repair/Recovery can restore your player back to factory settings and hopefully solve your issue. After performing the Repair, I recommend charging for several hours. Performing these steps also updates the firmware of your product:
Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
Hope this helps! If so, please let me know by rating this solution so that I may help others more effectively.
If you have any additional issues or questions, Consumer Care can be reached at 1-888-744-5477.
Jul 30, 2011 | Philips SA5125/37 MP3 Player
I have a CD ROM that is no longer being recognized by my Vista laptop.
Hi, if after a few computer restarts, it still fails to recognize, save your important docs etc, and do a system recovery back before the time you noticed the error.
If after 2/3 attempts still no sign, you are looking at a complete system install!
But first try accessing "Device Manager" clich DVD/CD/Rom Icon. Click Remove.
Restart computer, hopefully this should force a new item found and installing prog sign should appear during startup?
May 26, 2011 | Computers & Internet
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
Tried to update iPAQ ROM, iPAQ died in middle of Install. Help!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.) Make sure battery is charged
2.) Locate the rom you want to use
3.) Remove machine fro cradle
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your PDA in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Highlight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from your Vendor in step 3.
10.) The PDA should now begin Flashing the iPAQ's ROM BIOS.
Aug 21, 2009 | HP Computers & Internet
My nokia 6500 slide is not detected on my p3 processor computer
hi ,
on your p3 laptop/desktop go to the device manager and update usb drives (DO NOT CONNECT your phone). Before that uninstall pc suite. Then reinstall again.And follow the on screen guide how to connect the phone.
Apr 11, 2009 | Nokia 6500 Slide Cellular Phone
Toshiba A105-S4344 DVD-ROM not working
possible a loose connection, check to ensure you close the drive until a check is heard.check device manager to ensure device is listed and then go to its 'properties' ensure the current devis is recognized.you could also do a remove device,reboot, and have OS recognize a new device.clean the device with a lens cleaner.
Jun 22, 2008 | Toshiba Satellite A105 Notebook
CD ROM Boot
In the BIOS are you able to "discover" the CD-ROM device? There should be a way such that you can specify what devices are connected to the system.
The BIOS version should recognize what devices are attached to the system.
You may need to "flash" (upgrade) the BIOS. Now a days, BIOS upgrades are available on the manufacturer's website.
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Acer TravelMate 2702WLMi Notebook
Philips GoGear HDD6330 MP3 Player Logo
155 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
