Question about Canon PowerShot A460 Digital Camera
Canon Powershot A460 gets overexposed pictures with almost white image and sometimes white streaks especially daytime and outdoor though video take is okey.
    Sergeant:
  • 161 Answers
Change the exposure/ISO through settings.
This is the cause for over exposed images.
Posted on Sep 10, 2009
    Problem Solver:
  • 3 Answers
Need to replace broken flex ribbon for Powershot A460
Posted on May 09, 2014
I have a canon camera A460. when i used outdoor the image appears to be white..but when i used it indoor it appears okey plz plz plz help me.............
Posted on Jun 22, 2012
Hi.
It could be over exposure or maybe it is set to indoor or night settings.. Try setting it to automatic or to "outdoor" when you go outside and then take a picture.
Aug 02, 2011 | Canon PowerShot A460 Digital Camera
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
May 04, 2011 | Canon PowerShot A460 Digital Camera
My Canon PowerShot A460 cam is working well until yesterday, the biggest festival here in our place took place. teh flash, the lcd screen, etc is working... but, when i took pictures, the lcd screen turns...
Please try and reset the mode of the image to see if the LCD does not go blank when shown to higher light. Also if there is no issue with the indoor pictures then it is possible that the auto light detection is giving a higher value to reset the image balancing. Shift from Auto to manual mode and try.
Mar 18, 2011 | Canon PowerShot A460 Digital Camera
When trying to take pictures, looking through view finder or on back screen, it is blank. Am able to access menues and all though. Canon PowerShot S2 IS.
A stuck shutter is another common failure mode for digital cameras, but especially so for the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 11, 2010 | Canon PowerShot S2 IS Digital Camera
hi user,
either try puttin iso in auto mode or put it below 1000 if u r in day lite and adjust ur exolrsure setting which will even help u not getting over exposed
Sep 11, 2009 | Canon PowerShot A460 Digital Camera
My camera displays a "white screen" when i take photos "outdoors" or during daytime outside
Are you sure that you are in full "auto" mode when you are taking your pictures? Make sure that the mode selector is set to the first red camera (without the M) right next to the little blue arrow.
If you already are in full auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Your camera is not capable of taking 15 second exposures. Instead try putting it in manual mode, turn off the flash, take it in a darkened room, take the picture, and open the battery door while the red and yellow lights are blinking. Give it several tries, but note that the chances may be very slim for success as the shutter symptoms suggest that it is stuck open.
Jun 02, 2009 | Canon PowerShot A410 Digital Camera
Day Light Pictures looks over exposed
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
For your camera (the A460) it's not possible to set the shutter to 15 seconds. Instead, set it to manual mode, turn off the flash, go to a darkened room, take the picture and open the door while the red and yellow light are flashing. Repeat until the shutter becomes unstuck. However, I must say that the chances are probably not very good to fix this with this method. And unfortunately professional repair will be too costly. If repeated tries do not work, it might be time to consider a new camera.
Jun 01, 2009 | Canon PowerShot A460 Digital Camera
The picture we have taken was white/grayish screen- no images..
I got it repaired at canon service center in India for Rs 1900.
Next camera I will insure !
Jan 19, 2009 | Canon PowerShot A460 Digital Camera
Bright white exposure
This may be a ccd problem.
See this link.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
Aug 06, 2008 | Canon PowerShot A80 Digital Camera
Picture display result
Which mode are you shooting in?
You may have adjusted the exposure compensation so everything is washed out.
Whatever the cause, your images are overexposed. Try shooting in auto and the camera should take over the settings, but if you are in other modes, check your shutter speed, aperture, & ISO also. These are all things that can cause too much light and wash the picture out/OVEREXPOSE.
If you have any other questions or can give me more details, just ask!
Hope this helps!
Jun 01, 2008 | Canon PowerShot A460 Digital Camera
Canon PowerShot A460 Digital Camera Logo
1,140 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
