SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
SOURCE: Indesit Dishwasher DI67.Cycle phase lights(prewash and wash)flash
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
SOURCE: Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
SOURCE: Hoover hed6612 dishwasher wont work
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
SOURCE: have a hoover hed6612 dishwasher just over a year
