Question about Brother MFC-8840D All-In-One Laser Printer
I have a 8840D. the doc feeder became unglued from it hinges on the base of the machine. Also it does not feed docs any more.
    President:
  • Brother Master
  • 1,447 Answers
You configure your printer adf insert paper adf congigure copy quantity button press print key then make copy how much quantity
thanks
reply me comments
Posted on Sep 10, 2009
  • Sazeed Computer
    Sazeed Computer Sep 11, 2009
    off course print try my suggestion
WONT MAKE A COPY IN TOPFEEDER
Check the connection of the doc feeder to the copier. if you open a cover on the doc feeder does reflect on the copier? Ensure the doc feeder is aligned there is a small magnet right front side of the doc feeder that sits on top of a switch (Can not be seen underneath front plastic the copier when down. Adjustment bolts for the doc feeder is the rear right hinge only.
Mar 21, 2014 | Konica Minolta Bizhub C253 With Document...
Tip
Doc feeder Nogo/ Doc cover open?
If you can use the glass and can print, but you cant fax or use doc feeder, then have a look at Left hinge it will be cracked, If you push down on left corner you should be able to use doc feeder when in that position
Here is part that breaks on every machine.
Here is link to purchase one for $25 bucks, three screws and job done, easy fix!
on Dec 24, 2007 | Brother MFC-8440 All-In-One Laser Printer
Tip
Cant use doc feeder?
on Dec 24, 2007 | Brother MFC-8840D All-In-One Laser Printer
How to remove back corner panel at feeder cable in Brother MFC 8840D
If you mean the top left of the doc. feeder, you remove the cover by flexing slightly, remove a phillips screw, lift the scanner cover and there's a square hole on the lid with one of those flex clip retainers that you use a screwdriver to lift.
Jan 22, 2010 | Brother MFC 8840D All-In-One Laser Printer
Feeds document too far before it starts copying.
The doc feeder is a little finiky, try letting go of the doc as soon as the feeder detects a doc in place and not force it through the feed slot.
Jan 05, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Brother DCP8020D Document Feeder
Clean rubber rollers with metho, run a page by hand of laminate or stiff card threw the doc feeder. Stick it where the paper comes out of DF and ensure path is clear.
Push down on left side or tape down little black switch (rear left corner near glass)while trying to use df to confirm hinge aint the issue
If it is the rollers it should feed when paper is "helped a little" with hand at feed time
Ensure prints ok when using glass instead of df to know it is df problem
Cheers
Apr 28, 2008 | Brother DCP-8020D All-In-One Laser Printer
Doc cover open
3 screws easy fixf5f7046.jpgno tec needed bout 25 bucks for hinge see my other post re this problem 8025, 8820,8840,8225 same same
Dec 26, 2007 | Brother MFC-8840D All-In-One Laser Printer
Doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Nov 19, 2007 | Brother MFC-8440 All-In-One Laser Printer
Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Oct 11, 2007 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
115 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
