Question about Poulan "" Push Mower
Describe your Poulan "" Push
Describe your Poulan "" Push Mower Problem
Hard starting, runs in surges , then stops. will not run smooth. Mower engine (B&S 4 HP) is "FIXED SPEED" 20" type.
Again, when I can get the engine started, it will run in pulsating surges for a few minutes then stop on its own.
Drained gas tank, put in fresh gas, new spark plug, ...no luck.
    President:
  • 986 Answers
Please change your are filter,or clean it, I hope this helps you and thank you
Posted on Sep 10, 2009
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
Gas blower engine surges and shuts off when engine gets hot
check your fuel lines for cracks, could be sucking air or could be your carb needs cleaning, make sure you clean the screen inside the carb, if you run it with the choke on partially does it smooth out and quit surging, if so it is definitely a fuel problem. Hope I helped you. 2StrokeJim
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
Push mower with 4 hp Briggs motot surges, small
If the spring has only become dislodged, and not broken, you just need to find out where it goes. Take a digital picture of the carburetor from the top (you may have to remove the plastic shroud). Take another from the side, and from wherever else you can get an angle. Take the camera and small mirror with you to a place that sells mowers. B&S doesn't change their engines & carbs very often. You just need to find any mower with a 4 hp B&S, or even a 4.5 to 6.5 will probably be similar enough.
Jun 23, 2010 | Mtd 22" Yard Machine Push Mower
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
"Poulan" Push Mower: the mower will start but not stay running...
Have you checked the spark plug to see if it is fouled? If thats not it, maybe the air filter is clogged. If that still isnt the case try some B-12 small engines carb cleaner. Use it generously.
May 17, 2010 | Poulan "Poulan" Push Mower
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Jun 30, 2009 | Garden
Poulan "" Push Mower Logo
292 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
