Question about Dell OptiPlex GX520 PC Desktop
Power Had a thermal event, changed out the heatsink and fan. When attempting to power up, the light goes amber for a split second, then goes off. ABCD lights are off. Motherboard light amber. Same problem changed mainboard changed control panel changed power supply the only thing left is the case. Been at this for 6 months with little success. Will never buy another dell machine .
  • 2 more comments
  • motormike Dec 10, 2007
    couldit
    could it be a lazy (faulty) fan at startup
  • motormike Dec 14, 2007
    No the motherboard is a new one and inspects fine. Also replaced control panel ( switch ) and power supply.
    It starts after multiple presses of the switch sometimes up to thirty presses.
    Otherwise no glory as the switch turns amber whilst being pressed then instantly turns itself off'.
    This problem has not been resolved with replacing parts it is still as it was when purchased.
    Im at a loss
    Please help
    If any more info required please post requirements.
  • motormike Jan 17, 2008
    This problem looks to be unsolved everywhere i look.
    If anyone has any idea or experience with Dell machines then maybe they may have encountered something similar before.
    Any help in solving this issue will be greatly appeciated.
    PS Machine out of warranty so no help from Dell
    Sergeant:
    Champion:
  • 317 Answers
Check to see if something on the motherboard is fried, usually the capacitors are the first to go. look for swollen capacitors (the X on the top of the capacitor is not flat, usually leaking something or just swollen). If so, have the motherboard changed, if it's still under warranty, DELL replaces it for you.
Posted on Dec 10, 2007
Gateway gt5438 removed fan &heat shrink to clean, replaced now won't turn on.
When you removed the fan and heatsink (not heatshrink), did you remove the thermal paste from the bottom of the heatsink and the top of the processor? Also, when you reinstalled the fan and heatsink assembly, did you apply new thermal paste? If so, did you do so sparingly or did you gloop it all over the place? (This is one area in which more is definitely *not* better. You want to use the paste very sparingly as it is to help dissipate the heat and transfer it to the heatsink rather than try to be a heatsink itself.) Further, did you insure that you supported the motherboard from underneath when reattaching the fan and heatsink to insure that you did not crack the motherboard when locking it back down? Beyond this, did you reattach the fan power lead to the appropriate fan power plug on the motherboard?
Missing any of these details will potentially cause you problems and will cause the machine either to refuse to boot or to quickly go into a "thermal event" that causes a temperature-triggered shutdown so as to prevent damage to the machine. The caveat to this is that if you did not support the board when reinstalling and locking down the fan and heatsink assembly, then cracks in the motherboard could break power leads that would keep the machine from starting up. In that case, the only option you have is to buy a new motherboard.
Sep 26, 2014 | Computers & Internet
My dell dimension 3100 blinks amber. The Number 3 also blinks on the front. I've read that could mean a processor failure, whatever that means. But I opened the computer and there is an amber light...
I think your Thermal Paste on the CPU HeatSink might be dry. When this happens it like metal touching metal and the computer shorts out so it can't boot. You need to open the case and you will see 4 screws that hold the cpu heatsink on top of the processor chip. There are lots of videos on Youtube that show you how to replace the thermal paste (sometimes called thermal compound). I'm going to post a link here to one. I normally apply a thin coat of the paste all over the cpu and also on the heatsink. Then I put a coat of the paste in the middle of the cpu just like the video shows. This insures that I have coating all over the cpu and the cpu/heatsink. Don't worry as the video says about letting it dry. Put it on and turn your computer back on and start using it. https://www.youtube.com/watch?v=BQgCUcAAdac
How to Replace Thermal Compound
Mar 05, 2018 | Dell Dimension 3100 PC Desktop
Massive noise, now unable to access computer at all. constant amber light, not moving to next stage, nothing on screen, several thermal events previous to it blocking my access
Noise is most likely CPU Fan racing. Fault is most likely motherboard failure (Solid Amber power LED is usually MB and thermal events could be associated) Replace the motherboard
Feb 17, 2010 | Dell Optiplex GX280 (99301) Motherboard
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
System is saying that CPU fan has failed and shuts system down. I just replaced the fan and heat sync it is still saying this.
Thermal paste is applied between the heatsink and the cpu heat spreader or die. If you removed the heatsink to replace the fan you should have applied new thermal paste to the cpu or you may have burned it up. Try clearing the bios like dageezer said. Look for a jumper pin near the onboard battery to clear the cmos.
Sep 15, 2009 | HP Pavilion Media Center a1330n - AMD...
Pc shuts down ,reason cpu overheating
It seems to me that your pc is facing hardware problem.It is suggested that you contact local computer service to replace the faulty hardware..
Jul 25, 2009 | Computers & Internet
Dell XPS 200 Computer shuts off leaving blinking amber light
3 most common solutions to your problem are:
  1. Bad power supply; once it heats up will quit without warning
  2. Bad heatsink/fan; processor heats up and will lock up your Pc
  3. Bad motherboard
Try opening the machine and give the inside a thorough cleaning, paying special attention to the heatsink and fan. Once clean and you've ensured the fan is operating, put it back together and see if your problem is fixed. If not, a new power supply will likely fix your problem. Best of luck.
Greg
Jul 06, 2009 | Computers & Internet
P4VP MX Mother mother turns on but shuts down after few seconds
If you have replaced the power supply, the motherboard is the next possibility. Try disconnecting the power plugs from everything except the hard drive your operating system is on to make sure that they aren't causing the problem (possible but unlikely). Then restart the computer. If it continues to shut off you'll need to replace the motherboard.
Dec 14, 2008 | ASUS P4VP-MX Motherboard
Dimension 8400 will not boot, very loud fan.
I have a small business where I have worked on PCs for the past 14 years. I have had some of my clients that have brought me a few of these Dell 8400 to work on with the same problem. Will not boot and loop the start up, along with sounding like a leaf blower. After much trial and error i.e. Heat sink,cooling fan, power supply and motherboards. The first one I worked with by changing the heat sink, worked for about a week, then started doing the same thing. Replaced the Power supply with no results, same issue. Next was the Motherboard, still same issue. Last I pulled the processor out and found that the processor had over-heated and was damaged. In all I had well over $500.00 dollars invested and countless hours. Still the machine did not work, and still needed more work. Since this time I have had a few more of these machines cross my path. My suggestion is to scrap it and purchase a new PC. This is not one of Dell's better designs, and there is a tech issue from Dell related to this problem with the heatsink and the machine itself in the tech support on the Dell site. It states that they had a bad batch of heatsinks, but only replaced them under warranty.
Salvage what you can and build or have someone build you a clone.
Apr 04, 2008 | Dell Dimension 8400 PC Desktop
Power
You might have to change your power supply..(ex:SMPS or ATX)
Oct 23, 2007 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
327 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
