Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940FS...does not do a final spin/clothes wet
My washer is about 2 1/2 years old.
The last few loads, I noticed that the clothes are soaked. The final spin cycle does not engage. When I tried to select the drain/spin option, it drained but shut off with 7 minutes left instead of going into a final spin.
What is/are the problem(s)?
  • 396 Answers
If water remains in the drum the unit will not go into the final spin.There may be a couple of reasons for your problem.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. I believe the pump is about $60.00 and is accessible after removing the front panel under the door.
Posted on Sep 10, 2009
Hi i have an Frigidaire FAFS4474LW front load washer and it always stuck in the final spin last 6 minutes and it was keep spinning on the last 6 mins and never ended. It takes over 2 hours to finish a...
Thank you for your post, Tom Lau!
I see that you are having a difficult time with your Frigidaire washer, FAFS4474LW, taking long a time to complete a cycle and not rinsing the clothes out enough. This could be a possible problem with your sensor or control panel on your washer. You may want to perform a reset on your washer to help clear out any miscommunication within the washer. In order to perform a reset you would need to flip the household circuit breaker off for roughly ten minutes. If you continue to have issues with your washer after the reset I would recommend seeking assistance from a professional. This will help you to avoid any unnecessary part purchases. Best of luck! -Matt
Feb 17, 2015 | Frigidaire FAFS4474LW Laundry : Front Load...
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Model gltf2940fs clothes still wet only after the perma press cycle
Good Afternoon Friend,
I understand that your clothes are still wet in your Frigidaire washer, model# GLTF2940FS, but only after the perma press cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try the perma press cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLTF2940ES Front Load Washer
How do you fix Frigidaire GLTF2940FS slow final spin cycle?
if this is a front loader modelthen most likley cause is worn out motor brushes
Sep 17, 2017 | Washing Machines
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES3
I believe E47 is a door lock code.
You probably just need to replace the door latch.
Common problem with those units.
Sep 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
No final spin
is there stil standing water in the unit at the end??
Jan 26, 2008 | Frigidaire GLTF530DS Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
1,507 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
