Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of suction
It is fine on the carpet .but it has no suction in the hose.
  • cgillum Dec 24, 2007
    I also have no suction at all when trying to use the hose. In the upright position it works fine. Is there supposed to be a cap or something at the very bottom of the hose?
  • piriewife Dec 27, 2007
    suction variable in hose and great difficulty in removing filter in base of dco7
How did you get the cap out?
Posted on Dec 27, 2007
My vacuum had same problem and it had a cap stuck in the hose, worked fine after removing obstruction.
Posted on Dec 10, 2007
Not extracting water from carpet
Sounds like loss or partial loss of suction. Check hose(s) for leaks and/or blockages.
Aug 30, 2015 | Vacuums
How to fix dirt devil featherlite carpet cleaner loss of suction?
Hello! Below are general trouble shooting steps for your Dirt Devil vacuum to restore suction.
1. Check the hoses for clogs.
2. Clean and replace your filters if needed.
3. Check that your brushes are still spinning, if not, replace your belt with the recommended belt for your vacuum.
Hope this helps!
Jul 10, 2014 | Dirt Devil Vacuums
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
I have a dyson 07. Vacuum works fine, great suction using the hose. How do I switch to using the carpet vacuum. (I lost my instruction book) Thanks
If this unit has a suction hose built in to the handle, the carpet vacuum should start working after you return the handle hose to the proper position.
Dec 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of suction on hand tools (DC07)
It sounds like there's probably a clog in the hose. Drop a small coin or marble down the hose and see if it falls through. There's going to be a loss of suction in the power nozzle too, just not as noticeable when vacuuming carpet.
There could also be a clog behind the filter where the hose plugs into tank, or a dirty filter.
Nov 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi loss of suction on Dyson DC07 and I have changed the belt on the brushbar and cleaned all filters/removeable parts but still suction not very good, any other suggestions?
Check for a clog where the power nozzle connects to the hose. Clogs or leaks in the hose will both cause loss of suction/air flow. Another possibility is broken or worn out fan blades.
Nov 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Power goes on but will not pull up water from carpet
In other words, there's no suction/air flow. Check hose/s for clogs or leaks. Both will cause a loss of suction, but clogs will burn out the motor.
Aug 22, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a u3450 1500w hoover, suction on hose works fine, but carpet suction has never worked, how can i fix this?
There must be a restriction or blockage in the carpet suction pipe. Look at the port where the hose connects to the machine and check for any accumulation of debris or blockage. The same motor drives both suction inlets so it can only be that there is an obstruction.
Nov 02, 2008 | Hoover Vacuums
Sudden loss of suction.
Check the inlet down by the brush roll to see if it is clogged. Also check the belt to be sure it is ok. Is there suction at the hose? If not then it is still clogged.
Oct 30, 2007 | Kenmore 33721 Upright Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
111 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
