Question about Microwave Ovens
I have a 1989 Quasar Microwave MQ9968W D29170132 I Love the old thing and want to fix it. One day last month it made a loud buzz... then went out. No micro heat source is working. If you can help, please call Kim at 515-441-6232. Thank You.
  • 5,911 Answers
The Magentron is what generates the RF energy that creates the heat to cook. After 20 years, the magnetron on your oven has probably finally died. Due to the age of your appliance, I could only find one web site that still carries the part. A replacement magentron is available at repairclinic.com as item number 373304 and costs about $60.
Now...performing any repairs on the high voltage network of any microwave can be dangerous. Absolutely do not attempt to service the oven with the unit plugged in. There are voltage potentials of 3000-4000 volts in the high voltage network.
With the unit unplugged, you will have to remove the exterior case. With the case removed, the high voltage section is located on the right hand side. The magentron should be easily found with a connector plug that needs to be removed and some mounting scews.
Do not attempt to test the unit without re-installing the exterior case.
If you have any questions, please let me know. I hope this helps you.
NOTE: I'm impressed this unit has lasted 20 years.
Posted on Sep 11, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Quasar model MQ9968W keeps beeping every few minutes. How do I stop this noise?
Does it display any error code on the display like F1, F2 etc.,?
Mar 07, 2008 | Microwave Ovens
My new GE over the range microwave works fine but has a loud buzzing/humming noise when in use
This sound you describe is not normal and should be checked quickly, even if it means returning the item.
Mar 27, 2012 | GE SpaceMaker Microwave Ovens
My microwave magnets keep cracking
Have you checked out your waveguide and stirrer? Also ensure you have good connections & earths.
Feb 04, 2010 | Kenmore 62622 Microwave Oven
Was using it last night to heat something up. When almost done, microwave made a zizt type of sound and went off. I turned it back on and it continued cooking, but I started smelling burned plastic or
More common then you think, i have gone through a couple microwaves in the last ten years, they both failed very similar to what you describe. One popped the breaker one day, reset the breaker and it worked again but had an odd smell to it. I took it apart and couldn't find anything burnt or melted so i tossed it and got a new one, i didn't want a microwave burning the house down! I would suggest unless your really tied to that microwave that you just replace it for safety sake. Four years or forty years old don't matter anymore, i had one microwave, LG brand, that died two months after the warranty expired and it would cost more to repair it then replace the thing!
Jan 11, 2018 | Panasonic NN-H964 1200 Watts Microwave...
Can not remove microwave from wall
There should be screws in the cabinet floor ABOVE the microwave. Unscrew them, they will be long. Make sure you have someone to help you hold the microwave while you unscrew. One all the screws are gone, unplug the microwave and tilt the unit front first down about 45degrees then lift the back of the unit up 1-2 inches. Pull it forward and you should be all set.
Dave
Apr 20, 2009 | Microwave Ovens
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Need users manual
I need a user manual & parts list for a Quasar microwave, Model # MQ9968W built in 1991. Is this manual available in a pdf format or in hardcopy?
Nov 26, 2008 | Goldstar MA-1112 Microwave Oven
Microwave Buzzing When Not in Use
Are you using a 3 pronged outlet and is it grounded? If you have a 2 holed outlet and are using a ground eliminator adapter, try turning the plug around to reverse the polarity. If this helps, then it would be advisable to have an electrician to ground your oven.
May 22, 2008 | Whirlpool MH7140XF Microwave Oven
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Microwave Ovens Logo
352 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
