Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power light flashes 3 times then nothing
Power light flashes 3 times and makes and alarm or chirping sound then nothing. its a 52 inch rca hd52w59 itc222 chasis. I replaced cp150 and cp120/114 and also flyback transformer and still same thing? I also tested the splitter by putting wire in a glass and trying to power up tv but this didn't work either.
  • 1 more comment
  • maze0fw0nder Sep 11, 2009
    I have already replaced the flyback with the correct replacement and problem is still occuring.
  • maze0fw0nder Sep 12, 2009
    Does anyone know where i can purchase a horizontal output transistor it is a ITC222 chasis and a hd52w59 rca model number
  • maze0fw0nder Sep 22, 2009
    ok so i put a new horizontal output transistor in and now the tv turned on, so that's what was causing the chirping alarm sound....woohooo...Unfortuneatly the tv has horizontal lines and is fuzzy, Also there is a loud static or electricity sound coming from the flyback or somewhere near it on the deflection board. Does anyone have any idea what could be causing this?
  • RCA Master
  • 8,457 Answers
Turn down the brightness,and adjust the foucus on the FBT two buttons .
Posted on Sep 22, 2009
  • RCA Master
  • 8,457 Answers
Replace the intire board,not just caps.
Posted on Sep 12, 2009
This sounds like the typical bad fly-back transformer that is also known as the high voltage transformer, n=-Not really a repair for a novice so unless you know all of the safety notices with this set please do not attempt this repair as why save 100 bucks for something that could seriously kill you!!!!!
Posted on Sep 10, 2009
I have a 52 inch rca HD52W59. I have sound but no picture. HELP!
Possibly bad connections on flyback pins on power board, or bad connections on large capacitor near flyback.
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA 52"
Does any of the light flash? The light flashing is what tell what is wrong with it! If no flashing, then it could be the power supply or a grounding issue. Unfortunately, there are several things that could cause this! You might need to consult a TV repairman to check it out! They should be able to come to your house to look at it! Sorry, I could not give you a better answer!
Jan 06, 2011 | RCA HD52W59 HDTV Projection Television
RCA 52 inch. projection t.v. deflection module repair. Power indicator light comes on flashes 3 times but no picture or sound.
Try website like Tvrepairworld.com buy one their RCA capacitors kit,they put together.The instructional cd came with it,will detail which capacitors require changing.
Sep 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA hd52w59 out. Powerlight flashed 3x with chirp
Sounds like the Horizontal output transistor needs replacement.
May 27, 2010 | RCA HD52W59 HDTV Projection Television
Power light flashes 3 times and makes and alarm or chirping sound then nothing. its a 52 inch RCA hd52w59 itc222 chassis. I replaced cp150 and cp120/114 and also flyback transformer and still same thing? I...
Chirping sound is coming from coil on right side behind FBT, resolder then use Glue gun to glue on top of coil LL037,Make sure high voltage wire from FBT to Trippler is in Good this is what maybe causeing lines and fuzzy picture.Also make sure solder on all pinns of FBT are good.
Sep 22, 2009 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 chirping sound and light 3 times no picture
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
Sep 17, 2009 | RCA R52WM24 52" HDTV Projection Television
When i turn on tv u hear a whistle sound and light comes on then off then whistle sound it does this 3 time and i get nothing it is a rca hd52w59
Call UED for rebuilt Deflection Board 1-800-648-6657 With all the things that go wrong on those sets its better to just replace Boards
Sep 16, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca big screen, no power light,, dead!
Ck capacitor cp150 2200uf 16 volts if bad 2 more in same circuit also needs to be replaced 220uf 35v.ck second ribbon connector on deflection board make sure it is in correctly,or set will not come on.
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
421 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
