Question about Zenith Z19A11S TV
TV randomly shuts off and does not come back on unless you unplug it and replug it back in
  • intheraider Sep 10, 2009
    well to be more clear (sorry about eariler...) say i'll wake up and make coffee and turn on the television it will turn off about three to four minutes later and refuse to turn back on upon pressing the power button. the only other way i could get it to return to life so to say would be to unplug it. Upon replugging it in. I can turn it back on, however three minutes(or less) later it will repeat the cycle until I just give up and drink my coffee in silence.
  • xCAUSALITYx
    xCAUSALITYx May 11, 2010
    Hi, When it powers off, lets say its a typical day - You wake up make a coffee and switch the TV on, now from the time you switch it on how long is it before it powers back off again and does it power off at the same time roughly the next day when you first power it on. So - 20-30mins or 30-60mins or 1-2hours, its important to know this first as I can then tell you what the problem is, so be as specific as you can. Thanks
    Problem Solver:
  • 12 Answers
This is likely caused by voltage leakage which happens due to a build up of dust and other contaminants that make its way into the inside of the set.
1. Unplug the set for 4 hours or overnight and leave unplugged.
2. Remove the back cover and vacuum off any excessive dust and dirt.
3. Using a damp cloth, clean around the neck of the picture tube where the large wire connects (this is the main power wire). Wait about 10 minutes and then re-wipe.
You may find that you need to repeat the process a number of times before the problem will be fixed entirely.
Zenith TV troubleshooting
Posted on Sep 10, 2009
Why does my sharp tv 32k-x1000 picture turn offand wont come back on unless i unplug it then replug in outlet
Main system control memory IC fault. Replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Sharp 32K-X1000 TV
Toshiba model 35D10 randomly turns itself off. requires unplugging/replugging at wall ooutlet to reset. problem has become more and more frequent.
replace flyback transformer (same type - equivalent will not work ) - this part's work is to supply voltage to TV TUBE - after 4 years ( 4 to 10 years - depending on usage ) this part becomes weak then in top brand TVs automatically TV senses this deffect & well in advance it shuts off TV to protect other components from getting damaged due to this flyback transformer ........... as on now in your case only flyback transformer is deffective - so replace it as early as possible ....... click below link for more details on how to replace it ......
http://www.fixya.com/support/t10123898-panasonic_ct_36hl43g_tv_just_turned
Oct 31, 2011 | Televison & Video
TV will not come on unless I unpluf and replug it
Power supply board have problems.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Akai LCT2715 27 in. LCD Television
Samsung HLP5063W looses picture, turns off wont turn on and more
Ensure that the TV is off. It may be advisable to unplug the TV as well.
2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
Make sure your TV is off and cool when performing this procedure.
Jan 23, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
Shelf stereo turns off by itself and stops working all together.
how loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Feb 04, 2008 | Philips FW930R Shelf System
Hitachi 27AX1B immediately shuts off at startup
you are going into shut down check regulator check for bad solder connections get back to me
Nov 02, 2007 | Hitachi 27CX01B 27" TV
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
Tv won't turn-on
ITS THE PICTURE TUBE ITS BURNT OUT - OR THE GAS HAS LEAKED OUT ANYWAY U NO LONGER CAN USE IT
Aug 22, 2007 | Hitachi (3223424A)
Televison & Video Logo
157 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
