Question about VisionMan Barebone
I updated my window vista OS.When I tried to install my Linksys Router I get the message Error 311 no wired adapter detected
    Novelist:
  • 142 Answers
Go to start>run>services.msc>wired zero configuration> stop the process, start the process again, restart the computer,
Posted on Sep 10, 2009
    Sniper:
  • 129 Answers
This could be the problem with your network driver which is overwritten by driver from Windows updates.
Try to overwrite by the .ini using device manager.
Get the compatible ethernet driver from your computer manufacture web site if dont have one.
Right click on MyComputer -> Manage -> Device Manager(expand the tree on the left side)
Under Network Adapters choose the ethernet wired adapter -> Update driver -> Choose Manually the .ini from the system where you stored the driver and update it.
Hope it will work fine
I get message says ( you're connected to the access point, but can Not find the internet ?
What is your OS?
The table shown below lists all Linksys adapters that will work with a Windows Vista environment.
I wonder if your OS is Win XP.Post back!
Minimum Requirements
• 400 MHz or Faster PC
• 256 MB of RAM Memory
• CD-ROM Drive
• Avaliable USB Port
• Microsoft Windows 98SE, Me, 2000, and XP
WUSB54GSC version 2.0 is compatible with Microsoft Windows XP, Vista 32 / 64-bit edition with latest updates and Windows 7 32 / 64-bit edition with latest updates
Product
Driver Vista 32 Vista 64 PCMCIA WPC54G V1 3.100.64.0 OK WPC54GR 1.0.3.0/2.0.1.9 OK WPC54GS V2.1 4.100.27 / 3.100.6 OK WPC55AG V1.3 4.1.2.38 / 7.1.0.9 OK WPC100 OK OK WPC600N 4.150.31.0 OK WUSB WUSB54GC V3 OK OK WUSB54GSC 4.1.20.0 OK WUSB54GSC V2 4.118.4.0/4.170.61.0 OK WUSB54GR 1.0.2.0 / 3.0.1.0 OK WUSB100 OK OK WUSB100 V2 4.9.9046.1 OK OK WUSB300N 1.0.7.2 / 1.0.3.2 OK WUSB600N 1.1.0.0 / 2.1.4.0 OK OK WUSB600N V2 1.4.4.0 / 2.3.4.0 OK OK
Dec 07, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
For that right click on my computer icon then click on property then hardware-<device manager.
Then you can see all driver list click on network adapter and enable it.
You can configure your router without disk too.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
May 16, 2010 | Linksys Wireless-G WRT54GS Router...
Error 211
When getting error 211, you will need to manually install the drivers for the adapter.
Exit from the error message, then remove the CD and restart your computer.
Plug linksys usb adapter, the computer will detect the adapter.
Right-click on My computer then click properties, go to Hardware > Device Manager.
Under Other Devices, you will see 802.11 g WLAN with an exclamation point. Right-click on it and select Update drivers.
Then insert the CD. (If the installation setup screen appears, just exit it.)
Then on the update driver screen, click browse and select your CD-ROM drive.
Then click finish.
If you are using Win 7, follow the steps from this link.
If you cannot open the link, just go to kb.linksys.com. In the search bar type 20873. Answer title: Error 211 - Installing Driver Manually for network adapters to work in Win7.
I hope this helps!
Apr 29, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Dell 3300 adapter
Let me recap, just one more time.
Your wireless router,
You updated the firmware(most have out dated firmware from sitting in the warehouse)
Broadcast SSID
Using WPA-PSK(TKIP) Security
Mixed mode(b and g, n if available) This is needed for wireless devices to work properly.
Channels 1, 6 or 11. These channels are the channels most wireless devices work on the best(I use channel 11)
Now for the printer. Download and run this patch to completely remove the printer from your computer.
The patch is password protected. The way around the password protected zip file is to open the zip file with Winrar or 7zip(.exe file)
Restart your computer.
After router is done, now setup your wireless print server/printer.
3300 Utility
3300 Firmware
Attach the 3300 to your computer using the USB Cable and insert the 3300 disk. Follow the instructions. It should ask you for the network ID, type of security and password.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Install the drivers, choose network, choose I'm using a wireless print server(if you do not see this, then choose add printer and you should see it then) and follow the instructions.
Thanks for contacting Fixya
Jun 05, 2009 | Dell 3300 Print Server
Wireless Router Causes XP PRO to Crash. I just purchase a Linksys WRT110 wireless router and installed it using the EasyLink setup cd. The install went OK but Windows XP PRO immediately crashed and...
my apologies it was a typo...
the command is eventvwr.msc
what you need to do now is install a program called radarsync (google it) AND BE VERY CAREFUL TO UNCHECK THE OPTIONS OF ALL THE TOOLBARS IT WILL ASK YOU TO INSTALL THIS IS VERY IMPORTANT.
ITS A FREEWARE THATS WHY ALL THE TOOLBARS but trust me you dont want them.
let the tool scan for updates for your computer install the update you find for the wireless card and reboot
you shouldnt be getting the problem anymore
please rate if his fixes your issue
thanks
Dec 14, 2008 | Linksys Wireless-G WRT54G Router
Internet connection shows good bars but can't connect to web
first, can you please tell me if what OS are you using?
: if its VISTA or XP, please remove the network profile in your laptop ...
then search again for the network ... by the way what router are you using ? if its linksys please update this thread so that i can assist you if there is a need to reconfigure.
goodluck
Nov 25, 2008 | Linksys WUSB100 Wireless Adapter
Error when connecting usb wireless adapter
hi there, windows vista, as we all know is more focused on to the security... but it becomes very difficult if it detects other devices as an error...
With vista you can try to run the installation CD for the router, so that the vista knows that there is a driver for that router, without that it will not recognize the router and will keep detecting as an error...
was i helpful?
for more help log on to http://primustel.blogspot.com
Nov 18, 2008 | Computers & Internet
New vista HP computer wont send e-mail
try to dl all latest updates and linksys latest driver for your os ok
Feb 09, 2008 | Linksys Wireless-G WRT54G Router
VisionMan  Barebone Logo
70 people viewed this question
Top VisionMan Computers & Internet Experts
David Payne
David Payne
Are you a VisionMan Computer and Internet Expert? Answer questions, earn points and help others
