Question about Fuji FinePix S1000FD Digital Camera
Fuji finepix s1000 zoom error lens is stuck out what can I do???
My camera displays a zoom error message and has a red light flashing. The lens is stuck out and will not go back in... Please help what can I do?????????????
    President:
  • 2,761 Answers
If you recently dropped the camera, you may have damaged the lens housing -- that will require professional repair. Otherwise, your problem may be as simple as low batteries or corrosion on the battery terminals inside the camera. Make sure that the batteries are fresh/fully charged. If the problem persists, remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and replace them in the camera. This cleaning works about 90% of the time, and I hope it clears up your problem.
Posted on Sep 10, 2009
I just slapped my camera when it did that. it works fine now O-o
Posted on Oct 05, 2009
Error zoom finepix s1000 fd
My first suggestion is to remove batteries and put a new set inside of the camera. Sometime the power fluctuation will jam the mechanism and give you a zoom error. If this does not solve your problem then the lens is probably damaged or out of alignment and needs to be serviced. I suggest you look for the local service center; I know Photo Tech is the authorized service center in NYC. www.phototech.com and they do most of those repairs at their facility.
Good Luck,
Paul
Jun 30, 2011 | Fuji FinePix S1000FD Digital Camera
I dropped my fuji finepix s1000 camera and now i have a red light and zoom error
The lens housing has been damaged and will need be replaced, the rest of the camera should be checked to make that there are no secondary issues before repairs are considered.
Jun 17, 2011 | Fuji FinePix S1000FD Digital Camera
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
Hi does anyone know how to repair or replace a broken zoom on my fuji finefix S1000 camera?
Yes, I do.
You will have to strip the camera down and desolder the main board from the control/flash board just to remove the lens. Once this is done then the lens can be dismantled and the control ribbons desoldered etc, etc....
It's a long job.
And watch out for the springs!
Jan 07, 2010 | Fuji FinePix S1000FD Digital Camera
My fujifilm S1000 keeps saying "Zoom Error"
same problem camera was dropped and have zoom error, since the lens and lcd are FINE i dont think it will be that much to fix
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
Camera lens wont extend, has zoom error
It seems the mechanism has been damaged or is faulty is someway.
The devices are very fragile and the slightest knock can send th askew.
As it appears to be new - lets assume it is a faulty camera and return it to vendor
Nov 06, 2008 | Fuji FinePix A360 Digital Camera
Zoom Error
If you are still under MFG warranty and bought it from Best Buy they will ship it to service most likely, If you have their service plan they will be able to ship it for service... this needs to be serviced by a professional repair place...
May 16, 2008 | Fuji FinePix A500 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Digi camare
The lens on your camera has become stuck due to being dropped, contamination such as sand, or a malfunction within the lens. If gently manipulating the lens itself does not free it then you will need to get it professionally repaired or replace the camera. David Millier Advance Camera Repair
Feb 07, 2007 | Fuji FinePix F401 Digital Camera
Fuji FinePix S1000FD Digital Camera Logo
927 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
