Question about HP DeskJet 960c InkJet Printer
Orange blinking light at cartridge icon - HP DeskJet 960c InkJet Printer
  • 776 Answers
The Amber light is designated as the "Ink Error" light. With regards to a 960C Hewlett Packard or almost any inkjet printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
Posted on Sep 10, 2009
  • 61 Answers
The rate at which the LED blinks will give you an idea as to the cause.
This link to HP will explain the LED codes.
3 Suggested Answers
SOURCE: Getting "E" error icon with orange light flashing above by ink drop icon
click on start, then click run, type in the word services.msc, you will then get a list of options scroll down the lost to the letter p and find the word print spooler. click print spooler once then in the left corner you will have to options, either to stop or refresh, before doing anything take the usb out of the back of the printer, then click on stop, then click start, then click refresh, after this put your usb back in the printer, and that ''should'' solve the problem. email me if works or does not, thanks
Posted on Apr 24, 2009
  • 26 Answers
SOURCE: orange cartridge light error keeps on blinking!
it sound like a bad carriage assembly: part # C4713-60039
it lists for around $147.
Hope this helps
Posted on Mar 24, 2008
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Deskjet troubleshoot My HPdeskjet 5550 won't print.: My HPdeskjet 5550 won't print. The orange light is flashing
hi..........
In this error condition, the following light pattern displays on the product control panel and a message might display on the computer:
  • Print Cartridge status light : On
  • Resume light : Off
  • Power light : On
Figure 69: The Power light is on and the Print Cartridge light blinksc02645167.gif
    hpweb_1-2_minus.gif Causes
    • The cover on the product might be open.
    • There might be a problem with one or both cartridges.
hpweb_1-2_minus.gif Solutions Follow these solutions in the order presented to resolve the issue. Solution one: Close the top cover on the printer
  1. If the cover on the product is open, close it.
  2. Press the Resume button (c01219285.bmp ) to continue printing.
Solution two: Determine the cartridge issue When there is an issue with a cartridge, a yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is. Follow these steps to determine the cartridge issue, and then continue to the next section for solutions to resolve the issue.
  1. Open the top cover on the product. Wait for the carriage to move. The yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is.
  2. Look at the drawing and then find the icon in the following figure that matches the drawing. Each of these icons represents a different cartridge issue. Use the icons to determine the cartridge issue. Figure 70: Determine the cartridge issuec02645168.gif 1 - Tri-color Cartridge Problem icon 2 - Black Cartridge Problem icon 3 - Tri-color Cartridge Low-ink icon 4 - Black Cartridge Low-ink icon 5 - Cartridges OK icon
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP DeskJet 5550 InkJet Printer
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Orange ink light blinks. printer will not print.
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
Apr 29, 2010 | HP DeskJet 932c InkJet Printer
The orange ink cartridge light keeps blinking. We
the problem is that your cartridges are expired or bad, just replace the two cartridges with a new one
Mar 16, 2010 | HP DeskJet 940c InkJet Printer
Hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Jun 18, 2009 | HP DeskJet 5652 InkJet Printer
Inserted new cartridges..orange light still on
Try re-seating the ink cartridges. A lot of times, the electrical contacts on HP's ink cartridges do not make a solid connection.
Jun 17, 2009 | HP DeskJet 880c InkJet Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Nov 07, 2008 | HP DeskJet 6540 InkJet Printer
On/off button & restore button blink green & orange; printer doesn't work
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
May 22, 2008 | Canon BubbleJet i320 Printer
HP DeskJet 960c InkJet Printer Logo
1,462 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
