Question about IBM ThinkCentre S50 8183 - P4 3 GHz (8183D9U) PC Desktop
I have a ibm thinkcentre desktop and the hard drive is blank and i have the restore cd's but not working how tdo i use them?
  • nmitelli Sep 11, 2009
    it says on the hard drive that it can't find the os. all black so i am going to try to boot from cd in bios to see if that works. i do have the 6 os disks and the recovery disk.
    I am going to try this step and see will let you know.
    President:
  • 3,278 Answers
To restore/recover an IBM system to its original settings, try booting your system and select F11.
But, when you say "hard drive is blank" ... what problem are you experiencing ... power issue ?? Error messages ???
Hope this helps.
Posted on Sep 10, 2009
  • IBM Master
  • 13,433 Answers
The computer needs to be set to start from the cd, make sure you got the right cd in the drive and then read and follow this page to change the boot order so that the computer starts from the cd - http://www.whitecanyon.com/how-to-change-boot-order.php
Restore factory settings without cd
if you still have the manufactures recovery partition on your system use that it will reset your pc and drivers to the day of purchase
Jan 07, 2014 | IBM Thinkcentre 8185 PC Desktop
IBM ThinkCentre 8183 (M51) does not boot
I think it is more than likely your hard drive is the problem, you get the splash screen and everything is working up to that point which tells me the motherboard is fine.
Jul 07, 2012 | IBM ThinkCentre M51 PC Desktop
Ibm barbados 8124 specification
Hi, Maybe you are having a hard time searching the model of your computer, the key word that you should used is ThinkCentre A50 only because the ThinkCentre S50 and theThinkCentre A50 including the type/version are all under on same category (IBM support website )
Summary of IBM Think center s50 8183
Make sure that the HDD is a SATA drive, not the older PATA. There is only one IDE connector, and if you put both the CD/DVD and the HDD on the same cable, the system will run very slow (at the native CD speed).
Upgrading of video is limited to PCI only, not AGP or PCI-X.
The memory is dual channel, so for it to run best the two DDR modules (PC2700) must be identical (preferably dual-channel rated).
System software is easy to get. Google away with "ThinkCentre S50" and use the IBM site.
or you can just copy and use this website address to redirect you to the page where the driver, software information and support including the complete specification are all there. http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-50535
I hope that i was able to provide the information that you are looking for .. Good Luck
Oct 04, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
My buddy has an IBM ThinkCentre Desktop and he wants to nrestore it to factory settings because it was used for a hotel and when they got thier new PCs they sold all thier old ones
The best way to restore the ThinkCentre desktop back to the factory default is to re-install Windows.
You need a Windows installation CD (XP, or Vista) with the product installation code. After installing Windows then install the Thinkcentre device drivers for this model desktop which you download from the IBM ThinkCentre WEB site, you may need to download the LAN driver from a computer that has Internet connection and install it on the ThinkCentre so it has Internet access to download the remaining device drivers OR you may decide to download all the device drivers and copy and install them on the ThinkCentre.
Apr 14, 2011 | IBM ThinkCentre S50 PC Desktop
Bought a used IBM ThinkCentre M52 8215-VAN S/N LK71288 for $5.00. Needed memory and hard drive. Installed memory. Don't have harness for hard drive. Not sure where to plug hard drive in. Has optical...
if you have any discs in the dvd remove them... it should boot to the hard drive when it doesn't find anything in the dvd. if you need to install an operating system put that disc in the dvd and boot from it. during the installation it will start to run off the hard drive. when you are done installing remove the installation disc.
Sep 30, 2010 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
Can a 2nd disk be installed on the ibm 8143
if your refering to another hard drive yes you will have to set the hard drive to slave and you might have to purchase a new cable ribbon, if your asking about a dvd or cd drive yes and you should set it to cable select
Sep 07, 2010 | IBM ThinkCentre M51 PC Desktop
Concerning a thinkcentre ibm 8183 pentium 3: I put in a blank new hard drive and am wanting to instal a new os from the dvd drive...using f1 to get to different boot options..i choose boot from dvd drive...
your bios settings are not saved because of low voltage of CMOS cell.
Change your cmos cell from motherbord.
CMOs cell gives power to bios flash memory so settings saved.
Aug 15, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Getting problem in formatting the IBM PC
check if the cable from the cd rom connected to your ibm pc if its ok , also check the master, slave configuration pins into the back of your cdrom. make sure that theres no conflict between the hard disk and the cdrom. Your cd rom may probably cannot be detected. make sure that it is working first. then install the hard disk. The hard disk must be in primary master and the cd rom must be in primary slave. then try booting it to your cd rom. also, try checking if your windows xp setup disk is bootable, it means that it can boot from cd rom. PM me if you have other experiences after doing what i adviced. Thank You.. heres my email. jmizpahadonai777@gmail.com
Aug 07, 2009 | IBM Thinkcentre 8185 PC Desktop
Can't load xp pro onto my IBM Lenovo M52 Desktop
Check to see if the CD is an upgrade. If so, load an older OS first and then use the CD to upgrade.
Dec 11, 2008 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Ethernet, Multimedia, Video Controller is not recognized
IBM has the worst site I have seen so far for driver downloads. I have posted a link for you to go to IBM. You'll have to go through the downloads & find what you need. Like Lan drivers, audio drivers, video & so forth. You may find a restore CD download. You do not want to install the restore CD. Just pull the drivers off of it. http://www.ibm.com/search/?v=14&en=utf&lang=en&cc=us&hpp=10&catx=Y1zkzPz66zazbAzNA&q=ThinkCentre+A50p&cp=top&lv=c&cat=P9&x=10&y=10
Good luck, this will take some time but should also work for you!
Please vote...
Jan 30, 2008 | IBM ThinkCentre A50p PC Desktop
Computers & Internet Logo
315 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
