Question about Dryers
TIMER NOT WORKING
ROPER GAS DRYER MODEL # RGL4632BQ2. KNOB ON THE TIMER DOES NOT PULL OUT, SO DRYER WILL NOT TURN-ON.
  • 999 Answers
The knob does not pull out on dryers. Turn the timer to the desired setting and push the start button. Eric
Posted on Sep 12, 2009
Whirlpool gas dryer Model#WGD4900XW1 worked on certain timer settings for 6 mos. Now it only works on one setting and turns off. One more note: you have to gently pull the timer knob for it to turn on
Hello David, We're sorry to hear about your concerns regarding your Dryer. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dryer. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 14, 2017 | Whirlpool Dryers
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
The start knob doesn't engage when pulled. Do I just need to replace the knob assembly? Is it difficult?
Take the knob off and try using pliers to pull the stem. Don't pull any harder than you would with the knob. If it works, you just need a knob. If it still won't engage, you need a timer.
Dec 07, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer not turning on
Yes sounds like bad timer. Price is retail but should be available online cheaper via eBay or amazon.
Aug 24, 2017 | Roper RES7646KQ Electric Dryer
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Roper Gas Dryer not heating.
Is the fuse on the picture is the one you bypassed:
The thermal fuse
- The wiring diagram which may help you.Here is information about prices n more elements that you may need.http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Thermostats-and-Fuses/index.aspx "Did I answer your question ?
Did it solve your problem?"
Jan 19, 2009 | Roper RGX4634KQ Gas Dryer
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Installation of part no. WE4M190 (timer) in GE gas dryer DPSQ475GT5ww
take off the back panel look closely at the timer you will see a tab that you carefully pull up a little and twist the timer off. to take off the knob in the timer opposite the knob there is a pin that you pull out and the knob will pop off.
Jun 10, 2008 | GE DBXR463GB Gas Dryer
Dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out first...Catriver..post back.
Mar 15, 2007 | Roper RGS7745PQ Dryer
Dryers Logo
88 people viewed this question
Top Dryers Experts
