Question about Kitchen Ranges
I am trying to replace my old slide in gas range (Magic Chef- model # 6498XTS with a new slide in gas range and am trying to find out if the new one will fit where the old stove was, here's my problem the Magic Chef (the old one) shows an installation drawing and the depth is 23 1/2, the Maytag lists depth as 28 5/16, now I did contact the Maytag support line and was told that "it should fit", I stink at measuring and am in desperate need of help, because my old range is not working anymore and my family is sick of ordering out, can someone please tell me if this new range will fit in the old range's space correctly, also both have a height of 36 and width of 30. thank you
  • wdpelle Sep 10, 2009
    I just rechecked the literature and you were right, I also made a cardboard template and it fit perfectly! I am so grateful for your help and I ordered the new range. Thanks again you saved me so much aggravation...
    President:
  • 704 Answers
The installation depths provided in the installation literature, are the minimum requirements for fitting the slide in range into place. You need to determine what the depth of your opening is where you intend to install the appliance. The depth shown on the installation instructions might be showing the overall depth of the appliance, including the oven door, which typically sticks out from the cabinet anywhere from 1-3 inches, depending on the brand, model, etc. The old Magic Chef might have only provided the needed depth for the oven body, and might not have included the front oven door projection, past the countertop, etc. Most cabinents are about 24 inches deep, so anything larger than that, will likely stick out into the room more, unless your cabinents are deeper than 24", you're looking at having the new slide in oven stick out past the front cabinet front/edge, by about 4 5/16". I'd make a cardboard template to the dimensions of the new oven and use that to see just what you're facing with the replacement oven. It could be possible that you've confused the depth with the width for the new oven, as I've not seen many ovens that are as large as 28" unless it was a Viking, or other really high end, professional style oven, etc. Check your installation dimensions again for the Maytag and make a cardboard template to confirm how much space will be needed. The good news is that you can remove the old Magic Chef, since it's not working, to allow you to make a more informed decision as to fit and clearances required for the new oven. Just be sure to disconnect the power to the range or unplug the power cord, if that's what it has, before attempting to remove the slide in. Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
Testimonial: "thank you, I will recheck the literature and make a cardboard template like you suggested, I really appreciate your help!"
Burners will light but the pilot light wont, what is wrong
Get an old tooth brush and clean them pilots. Use a straight pin to open the pilot just a hair. Remember the higher the pilot the more gas is used. The pilot lines are easily replaced by the way. Remove a screw at the backside of the oven control and slide the old pair out and install a new set.
Nov 03, 2010 | Magic Chef 31000 Gas Kitchen Range
F-7 and beeping is occurring on my Magic Chef,
Hi sixgunromeo,
The error code F7 means that the Function key is shorted or stuck. TO fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Dec 05, 2009 | Magic Chef 31000 Gas Kitchen Range
I want to replace my old slide in gas range (Magic chef # 6498xts) with a new Maytag slide in (#MGS5752) and the installation drawings are showing different depths one shows 23 1/2 (magic chef) and the...
hi..gud day ur magic chef is smaller than maytag? do u think the space of ur old unit is enought to fit the new one? 5inc are different.u waste ur money.
Sep 10, 2009 | Cooktops
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Location of pilot light on bottom of an old Majic Chef gas stove
please send model number...and how old in or about years..onthejob
Jan 01, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Trying to find model number of an old Magic chef gas oven
depending on age, sometimes on back, or even under the main top if it lifts up, sounds as uf you would need to replace the door hinges
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
Replace the switch lighter for magic chief cook top
I would like to replace all gas head(4 sets) of the Magic Chief gas stove in Thailand. How to find the service center?
Aug 16, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
341 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
