Question about Husqvarna Garden
How do I get the clutch drum off? Husky 55 Rancher
    President:
  • 2,220 Answers
A YouTube video shows the procedure using a Husqvarna 350 here:
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. I looked at IPLs for the 55 & 455 and didn't see any special tools.
2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and be cut when the piston rises.
3. It is probably a left handed thread (tighten it to loosen it).
Let us know how it worked for you. GL
Lou
It appears the 455 must be a "spur" type chain drive sprocket. the 55 offers the option of a "rim and spline" drive sprocket. If replacing the clutch drum I recommend the "rim and spline".
Posted on Sep 10, 2009
Testimonial: "Works great , thanks so much. "
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: I have a Husky 55 Rancher, was sawing a tree and
Yes. this checks both. Change the plug first <$5 plug >$50 coil.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Ignition module gap
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 19, 2010
I need to know the size and thread for the Husky decompresion valve,so I can retrofit on my Husky Rancher 55
Well it will be metric thread. The to easiest ways will be go to a nuts and bot shop, thay will tell you and should have the tap you need to cut the thread into the housing or if you buy a thread-gage, that will tell you the thread pich
Dec 17, 2013 | Husqvarna Maintenance Kit For Model 51 And...
I want to buy a 16" 3/8 Husky bar that fits the 55 Rancher to replace my 20" bar on my Poulan Pro 5020av...where can I get it?
as long as your 5020av has a 3/8 sprocket it will work they make a professional landowner and homeowner for these saws each costing different prices tell the dearler what your doing and he can decide what you need
Dec 10, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husky 55 rancher - I rebuilt this saw but now it won't start. Seems like not getting enough gas. What should I check for?
Check for plugged fuel filter and muffler. Check the fuel lines for decay or damage. Did you service the carburetor? Make sure the lower chamber diaphragm is not hard or cracked. Did you change the two jet settings? Put some fuel mix into the plug hole and pull it through--you should get a pop or two. If ok, then concentrate on the fuel problem. If no spark at the plug, check the ignition module gap to the flywheel magnets using a thin business card for a gauge. Hope this helps!
Jun 06, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqavarna rancher 55 repairs
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston.
• I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it).
• Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  1. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 01, 2010 | Husqvarna Chain Saw 20" Bar
Changing clutch drum on a husqvarna 455e rancher chainsaw
You have a couple of options. Oregon offers both rim and spur sprockets to fit your saw. Rim systems are initially more expensive but replacing just the rim portion is less expensive than 2 spur sprockets.
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
A part number for an OE spur sprocket and illustrations that may be helpful for disassembly may be found here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000; black numbers on silver tag 90s; silver numbers on black tag 80s)
15 = week produced - March
Your saw has an outboard clutch, this is a very guide for removal:
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
More questions or if I can be of more assistance please reply below. Good Luck. HTH
Lou
Feb 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a rancher 55 and I had to reconnect the gas line to the carburator and now I can't reconnect the throttle I need a view of the throttle assembley. Where can I find one thank you
55 IPLs start at page 4 but I doubt it has the level of detail you need.
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
I suggest you go here and join.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
The following thread is about your saw. Someone of will probably be willing to provide the photo you need. There are other threads where your saw is discussed.
http://www.arboristsite.com/showthread.php?t=122545&highlight=55+rancher
I must warn you. Many that frequent here develop an obsession with chainsaws. When I joined I had 1 and had only owned 2. I now own 7 and am always on the look out for a new one.
Good luck with your project. HTH
Lou
Feb 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky 350 leaking gas from white plug in gas tank
I have a rancher 55 and it was leaking gas, i replaced the gas cap. That solved the problem.
Sep 30, 2008 | Garden
Garden Logo
483 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
