Question about Whirlpool Refrigerators
Door cam problem for an older Sears Kenmore 22 refrigerator,
I have an older Sears Kenmore 22 refrigerator, number 106.8552970. Over the years I've ocassionally had to replace the door cam plastic at the lower pivot. The last replacement did not last very long - perhaps about 6 months. I was finding flakes of plastic on the floor below the pivot. Upon dissassembly I found the plastic castle-head-like shapes worn down. I replaced them Sunday with a set of Whirlpool FSP 2155311 door cams which I obtained from a local appliance parts store. Now, 4 days later I again find that flakes are appearing and the door seems to excessively bind in the fully open position. It worked fine initially. Noticed the binding 2 days ago and the flakes last night. HELP!!!
Ed
peyton32034
  • 410 Answers
SOURCE: My kenmore refrigerator kept running.
from your description it sounds like your hearing the start relay trying to start your compressor. most likely this relay is bad and needs replacing.
Posted on Dec 18, 2007
  • 12 Answers
SOURCE: Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Posted on Aug 05, 2008
huuum
  • 750 Answers
SOURCE: whirlpool refrigerator stop cold but frosting bad
Hello Catherine Fu,
Welcome
You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
Help!! It is an very expensive refrigerator and ONLY 4 years old .
First,I think you need to have a new tech.
It sounds like you have either an air leak allowing out side air in and this causes the icing.
Or you may need some freon (coolant gas) .
If your freon pressure is low it can ice up.
Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
You need to call a different tech and let him see what's happening.
Some company that is reliable!
Let me know what they do for you.
God bless, Huuum
please remember to leave a rating.
Posted on Oct 05, 2008
  • 833 Answers
SOURCE: Squeaky Door on GE Arctica Refrigerator PSC23NGMB
Have you considered the strppingt around the door?  If so, you can use silicone spray for it or anything else around the fridge.  Wipe up excess.  There is a version of the spray which says that it is dripless.  I think I saw it at ACE.
Posted on Nov 15, 2008
  • 37 Answers
SOURCE: Refrigerator door fell off.
Should be able to just replace the pin if the door didn't get damaged. If you go to Sears.com, put in the model number and you can get a parts breakdown and order the parts yourself and save some money.
Posted on Apr 25, 2009
The support condiment of my door is broken.
That sounds like a Kenmore Canadian model number. Contact Sears parts in Canada and give them your model number and ask them about a part replacement I'm limited here in the US to answering your question the reason I have no documents on your model numbers
Nov 18, 2015 | Kenmore Refrigerators
When will there be a s sale on Samsung French door refrigerator
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Sears has a "Friends and Family Night", twice a year. You need a ticket to get. Contact: "Sears Customer Service". Also, Holiday week ends.
You may want to consider a "Sears Outlet (Scratch & Dent) Store". You can save several hundred dollars and get a one year warrantee.
Both Samsung and LG have the highest repair rate.
Also stay away from bottom freezers and units that have either the icemaker or the ice bucket mounted on the door.
Consider: GE, Kenmore, Kitchen Aid, Amada.
Mar 05, 2015 | Samsung RS2530BBP (25 cu ft) Side by Side...
Were is the defrost timer in double door Kenmore refrigerator
What's your model number? Kenmore is just a name Sears slaps on appliances made by many different manufacturers. It's difficult to say exactly where it's at if you don't provide the model number.
But, be that as it may, it's never in the freezer section. If you have an older unit, try looking up top near the thermostats inside the fresh foods side. If you have a really old unit, take off the kicker grill plate on the bottom of the refrigerator and look to the left side for it. And, if you have a newer unit that is digital, it's part of the main control board.
Good luck
Nov 14, 2014 | Kenmore Refrigerators
Kenmore model 106
post a model number and more info. i would suggest you do a google search for your model and then find the sears site that has a picture break down of the parts. then you can find the broken part and order it thru sears parts.com
Dec 30, 2013 | Kenmore Refrigerators
Kenmore Fridge not working - electricity is fine, no dust
There so many reasons for the answer to the solution that I want to ask you a few things about your refrigerator.
1. Sears uses model numbers that protect their brand names and models to keep them Kenmore. For example Kenmore may be made by a very well known Brand name with a different model number. The truth for a sample Kenmore Brand Name would look like this 214.2654789 for example only.
2. Location of most Sears Brand Names are located near the bottom of the fresh food section door and just near the door seal. I will send photo locations soon because my computer that I use to upload photos and description's in doing a long virus scan.
Now can you tell me the model number, are the lights on, are fan's running or is it just like it's unplugged?
Answer those or most of those question and I will help you get your Kenmore running again. Thanks, Sea Breeze
appliancepartsse@yahoo.com
Aug 03, 2009 | Kenmore Refrigerators
How to remove inside panel of refrigerator door of the Kenmore French Door to replace the tubing for the water bottle?? Thank you!
Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food section door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there. Go to my Site and Scroll down to model number locations photo, Thanks, Sea Breeze email appliancepartsse@yahoo.com Web Site http://servicepartstec.blogspot.com/
Jun 11, 2009 | Kenmore Refrigerators
How to replace the motor in kenmore ice maker. How to get in.
Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 09, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Is there a kenmore refrigerator recall?
The 800 number is available at:
www.techimo.com/forum/imo-community/145834-lg-electronics-sears-roebuck-recall-refrigerators.html
May 30, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Trouble locating model numbers
i put your model number into the system its here, what did you need? you want to replace the refig with the same refrig??? if htat s the case take your model down to the sears showroom and the salesman will be able to locate the latest year model number for you. the number you have is probably a few years old they have moved on to new numbers,possible same dimensions just differnet numbers
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=Bgl2MEGpgV3YgMXSX1xt+w**.shcapp3005?modelNumber=106.53603202+&pop=flush
Nov 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
227 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
