Question about Samsung Pleomax PWC 3800 Webcam
Mic how do i use the activate the mic
  • Samsung Master
  • 2,855 Answers
Before you can set your mic as default in any chat program you have to make it default on your computer first. Especially if you have a laptop where you will now have multiple choice for mics
Vista audio set-up
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and set sliders to 100% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Retest
When you go into a program to use your mic you will have to tell that program which mic is default
WLM (MSN)
Open menu > Tools > Audio & Video setup
SKYPE
Tools > Audio setup
Posted on Sep 10, 2009
The mic does not work but I can gear people
Looks like you are using more mic's on your system.(The internal mic within a laptop?)
See within the operating system if the correct mic is activated.
You must always callibrate a new mic within the operating system.
Good Luck.
Aug 03, 2011 | Logitech (980174) Headset
My acer aspire 5742-7653 internal microphone is not picking up sound. what's the fix for this?
go to the sound mixer(double click on speaker mark on the task bar). and then click on option, and then properties.you can see dialog box with recording and playback settings.
first mark on playback , and check activate the mic on that, if not put the tick on selection box.
then mark on recording. check the mic activation same as that. then click ok. you can see recording mixer.
OK now check have an advance controller button near the mic controller . if not click on option, and check have a tick with the advance controller. if not put the tick in frount of addvance controller. now already you in recording mixer. now you can see that button.
after that, click on "select" check box with the mic and increase the level to top. then click on "advance" controller, and put the tick on mic 1 boost. then close all windows and check the mic,
using via some recording software (like as windows sound recorder ), or activate the mic for working with speakers via put the tick on the mic tab on playback mixer. ( when that can hear like some siren noise , pull down the mic level to control that)
Dec 05, 2010 | Acer Aspire One PC Notebook
What is the switch for on the Phantom power unit at the end of my AKG C747?
Hi,the switch for the phantom power on the microphone is to activation of the mic.Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantompoweronthe mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
Oct 20, 2010 | AKG C747 Professional Microphone
I'm buying a Rode NT1A, it comes with a shock mount, pop filter, xlr cable etc. What else besides a USB converter cable to I need to have this mic work it's full potential on a PC?
Hi, what else do you do think you will need? I don't think you will need any other thing except that before you use the mic, the switch for the phantom power on the microphone is to be activated .Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantom power on the mixer and switch on the phantom power on the mic,and problem solved.
That all you will need .
Thanks for using fixya....
Oct 20, 2010 | Rode NT1A Professional Microphone
Im having distortion problems on my microphones, how do I activate the compressor on my mixer?
You can't activate something you don't have. The XENYX do not have compressors built in.
If you are getting mic distortion you are not properly setting up the mics.
You one at a time press the PFL down and have someone yell at the mic the loudest they will ever be. You adjust the trim control for that mic to be below the clip on the LED display. The you turn that PFL off and go to the next mic.
From that point all mic adjustments are from the slider. If you can't get enough gain, then back off ALL the other non-mic inputs and crank up the main slider and/or the power amp gains.
You have to learn to balance all the gains.
There are instruction videos on YouTube under "Soundboard".
Sep 16, 2010 | Behringer XENYX 2442FX Mixer
Built in mic not active acer aspire 5535
1. go to volume/ speaker icon (right down taskbar)> open mixer> device> property> "tick" microphone.
2. do not forget to "un-tick" microphone mute
Apr 28, 2010 | Acer Aspire 5500 5570-2609 Laptop
How do i get the mic to work on my headphones they r headrush headphones
you need to activate it from volume panel. go to Options then properties. from the properties panel just check everything applying to mic like "mic volume" "front micro" so on and it'll appear in the volume panel. from the volume panel just disable mute to activate the mic
Oct 14, 2009 | Computers & Internet
I got a problem with my mic
Good day, sir/ma'am , there are several reasons why a mic does not work, let me give some. 1. its not activated, to check if it is activated, load the sound recorder program on windows. press record and shout on the mic, wave patterns can be seen on the recorder. 2. you may activate the mic and speaker if you cant hear the voices by. opening the volume control settings, options, properties, place a check on mic volume. there are other optons as well. 3. the mic is physically damage due to open wiring. get a new one. hope this may help. thanks
Jul 16, 2009 | Radio Communications
How to activate mic phone
Feature 1 or function 1 will work
Mar 04, 2008 | NEC Electra Professional ETW-16DC-2
Ps3 rockband mic not loading??
I used the controller to activate it thanks for your help it worked!!!
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Samsung Pleomax PWC 3800 Webcam Logo
129 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
