Question about Panasonic PT-47WX49 47" Rear Projection Television
Where can I get a replacement mainboard for a Panasonic PT47WX49
Hi:
The mainboard (printed circuit board) on my Panasonic PT47WX49 has died. What is a good source for locating a replacement. I called Panasonic Parts and they do not have a listing for it. But it is hard to believe that I cannot buy one. Even a used one would be fine.
Thanks
John
    President:
  • 1,653 Answers
You might find the following article very useful. Look at both parts!
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html
Posted on Sep 10, 2009
What is a pcb printed circuit board and where are they located on a th-50px80u plasma tv
A PCB Printed circuit board is every single board in your TV. That is what PCB stands for Printed Circuit Board.
Jul 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
When i power up my projector the screen projects some vertical colored lines and none of the buttons work. i cant even get any tpe of picture on the screen
Hello Lvhrj, Hi!, the projector unit has basically two circuit boards, one for the main board, that controls the lens, lamp, blower fans, and projector circuit controls, the second one is the power supply board, since as you mention, there is power on the projector, I suspect the problem is on the mainboard, Servicing this type of board is no nonsense, double sided and its way beyond our experience, but we do replace the entire main board, so the only solution is to replace the main board, this requires tech knowledge, if you are not that kind of person, I suggest you let the experts do it for you, call your service center, or your dealer.
Feb 10, 2010 | Panasonic Office Equipment & Supplies
Pt47wx49 panasonic rear projection tv has very dark tv scenes
Has this problem been getting progressively worse? I would suggest cleaning the CRT's inside the tv with lcd screen cleaner or something similar. Make sure the tv is unplugged, all you have to do is undo some screws on the back to gain access to the inside of the cabinet. Hopefully that's all it is. Your set has no lamp if it is a Panasonic Pt47wx49.
Nov 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
No power (dead after a lightning storm hit the house. Tried replacing the two power circuit boards and have a current going in and all around all circuit boards. Still no sign of life when plugged in...
If its after a lightning storm, it really could be anything. Your mainboard could quite possibly be shot. In fact almost anything in the TV could be damaged by a big surge. It could even be that your backlights went out from the surge too.
Does your power LED come on? What is it connected to? Directly to the power board or is it connected to the mainboard? If you have current through all the circuit boards, you may have a burnt tuner or chip on the mainboard.
Might not be worth fixing depending on the size/model. If its a big LCD, you could probably get a good deal on a working one of the same size with a broken LCD panel (~$100). Then you can just replace the broken LCD panel with yours and you have a fixed TV.
Aug 15, 2009 | Panasonic Televison & Video
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Panasonic projection tv (shuts down)
check r517 on the power supply board if it is burnt or damaged replace it with a + or - 5% 10K 1/4 watt resistor this has been a problem in other units.
Oct 03, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Mainboard Replacement for PT AE700U
Hi CFP123
You will have to phone Panasonic for the part - do have the part number on the board handy when phoning in.
As for the pricing it depends on which country you are in , but it's normally between $100 - $150
May 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic pt47wx49 taking out board A to replace IC on heat sink
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board (not sure what you mean by white clips, but you should be able to take out just the convergence board) and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conducting piece of plastic to push the heat sink when doing tests.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Feb 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
