Question about Water Heaters
Water only gets tepid and not hot - Water Heaters
    Problem Solver:
  • 4 Answers
Check the temp setting first if its at 120 you need to check the elements
Posted on Oct 15, 2009
  • gworley55 Oct 15, 2009
    check the temp setting first if its at 120 you need to check the elements
Everything works but it appears that the gas burner is not recieving enough gas and the water is only tepid
there are a lot of info left out here,
1.is this a new install? if so was this unit setup for propane & now being used with natural gas? propane being heavier uses a smaller meter jet than natural gas(which has more volume. this would keep the water from getting really hot & it may run continually.
that's only one question. there many more.
I would have someone who knows about water heaters look at it.
Feb 19, 2015 | Water Water Heaters
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Dec 18, 2013 | Taco 006-B4 1/40 HP Bronze Circulator Pump
We have a reliance 600 about 4 years old. Recently when you turn on the hot water you get a lot of air out of the line. Also the other day we had scorching hot water and then no hot water. We reset the...
1) Reliance 606 Electric water heater, AO Smith subsidiary.
Good brand.
Copy following links:
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) First: Test elements using cheap multimeter from hardware store.
Next: If elements test OK, then replace both thermostats.
3) If that doesn't solve problem, then add comment Jan 2013 and report what you find.
Jan 26, 2013 | Water Heaters
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Getting really hot water to the kitchen but only tepid hot water into the bathroom and ensuite. Do not need to put on the cold tap at all in the bathrooms but you can't hold your hand under the tap in...
If some taps have really hot and others luke warm, then you might have defective mixing valve, check valve, or crossover on single handled faucet.
http://waterheatertimer.org/Crossover.html
Crossover can also cause stacking event. Stacking could be part of puzzle.
http://waterheatertimer.org/Stacking.html
Once crossover or check valve or mixing valve problem is solved, if you have really hot water to some taps, then turn down thermostat to avoid scalding.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Add a comment for more help.
Jun 13, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Dec 15, 2009 | Water Heaters
Water Heaters Logo
65 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
