Question about Lexmark 4226 Model 302 Matrix Printer
Line spacing problem with queries
When I send queries to this printer, it runs every page over the perf before starting a new page. Line spacing seems to be more than single space, not quite double space. There is no setting for line spacing, other than proportional spacing. I'm using fast draft, 10cpi. Form length is set correctly at 11. Help!
How to change Tally T2240/24 Matrix Printer character and line spacing
This sounds like an Microsoft Excel issue. The Windows printer driver controls how printing is done regardless of your printer settings.
Excel controls the format of your page with column widths and line height. Depending on your version of Excel, after selecting your print range and your margins, you will need to go to Page Setup and select "Fit to" -- select 1 page wide and a larger number of pages tall.
Jul 25, 2014 | Tally T2240/24 Matrix Printer
Printer double spaces between lines
That is a setting in your printer setup menu under options or advanced. Page set up should come up under advanced or as its own tab.
Apr 09, 2014 | Citizen iDP-3550 Matrix Printer
How do you fix error code p2x30 on a kodak ex110?
P2X30 One Line Description: REGISTRATION F-PERF DETECTOR: No PERFS within 1.1 sec (2-frames) after start-up. Error Type: Log Only Error Description: At the beginning of a print cycle, Logic and Control measures the duration between MAIN DRIVE AY energizing and the detection of the first F-PERF by the REGISTRATION SENSOR. If more than 1.1 seconds (2-frames) have elapsed before the first F-PERF is detected, a P2X30 will be recorded in memory and a shutdown will occur.
the image loop has perfs or slits that the machine uses for position and timing of the paper and image. usually damaged loop edge, sensor, or loss of drive will cause this error.
Sep 18, 2013 | Kodak Digimaster Ex110, Same As Canon Ir...
Need to send 8 page fax. How do I do this with A1500? Can't seem to get past first page.
Save your 8 pages to file start a new fax select attachment add you file to the attachment & send your fill
Dec 03, 2009 | Compaq A1500 All-In-One InkJet Printer
Brother9440 black dots appearing in line close to middle
it is problem drum spot open ypur printer drum unite and chack it or buy new one
Jul 23, 2009 | Brother MFC-9440CN Laser Printer
Wont Print a Large PDF File
You don't say what kind of printer or computer so it's a little hard to narrow down what is happening. That said, it sounds like you've running out of disk space while the print driver is trying to make data to send to the printer. If you can print the 1st few pages (try 4, then 3, etc.) then this is almost certainly happening.
Check how much free space is available on your hard drive.
Carl
Dec 09, 2008 | Office Equipment & Supplies
VERTICAL PRINT LINES
Check the front paper exit rollers for fit and alignment also the paper deck guides close to the planten area, if the printer is dropping print vertically down one side of the page, this can be caused by debris or anything that lifts the caridge assy the slightest bit, also check the print head seating and ribbin cable for proper alignment
Apr 04, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
IBM 4234 dot matrix
Sounds like the configured paper sized does not match the actual paper page height. So that when it does Top Of Form paper movement the paper stops slightly too low. Doing several form feeds should confirm this. If this is it then reconfigure the paper size to match the paper. Also measure to paper to see if it matches what you want it to be.
Mar 04, 2008 | IBM 4232 Matrix Printer
Printing Blank Sheets
What document you sending? word ?
does demo and conf page come out from printer OK ?
Try installing drivers again
Sep 26, 2006 | Konica Minolta magicolor 5430 DL Laser...
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
