Question about Frigidaire FRS26RLECS Side by Side Refrigerator
I have a frigidaire side by side refrig. mod frs26rlecse the evaporator fan don't work I put new one , but the new one don't work neater .the freezer side work but freeze in the bottom , and the frige side don;t be cool enough. thanks what I need to do?? Comments: Sep 09, 2009 - I thing the problems be electric or be on the timer defrost.I don't see freon leak. because the freezer works ok. but the problem is because the evaporator fan don't work and don't send cold air to the frige side.
  • viento86 Sep 10, 2009
    thanks I will to check the control board
    President:
  • 1,653 Answers
If you have replaced the fan and it is not sticking or jammed then the controller board is the main suspect.
Posted on Sep 10, 2009
2 Suggested Answers
Milleniumboy
  • 106 Answers
SOURCE: i have a frigidaire side by side refrig. mod FRS26RLECSE
HELLO,
This fridge may be lacking the chemical called freon, a typical coolant agent used in refrigirators, try to replace the coolant, and then let the fridge run some time. It should be back on cooling as normal...:)
Posted on Sep 09, 2009
Frigidaire side by side refrigerator/freezer has h1 flashing on refrig. side
H1 is temperature detected as too warm. Is compressor running? Are evaporator and condenser fans running? Is there frost build up on inside back wall of freezer?
Sep 13, 2017 | Frigidaire Refrigerators
Refrigerator runs continuously
How well are the door seals and the door to the ice dispenser is it closing all the way. Condenser clean?
APPLIANCE 911
Apr 14, 2016 | Frigidaire Refrigerators
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
I have a frigidaire side by side refrig. mod frs26rlecse the evaporator fan don't work I put new one , but the new one don't work neater .the freezer side work but freeze in the bottom , and the frige...
HELLO,
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrig side not working
sounds like the circulating fan(evaporator)is wearing out, this problem is very hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Refrigerators
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
I have a Domestic 2804 frig in my RV, The freezer works great but the frig part will not cool at all, can you help
All cooling takes place in the freezer. The refrig/fresh food side is a parasite, depending on cold air circulation from the freezer side. The fan in the freezer provides that circulation, and usually the freezer control setting determines how much air is moved into the refrig side.
If the fan is up to speed and the both controls are set in a middle position, the refrig side should be fine. if the problem continues, replace evaporator fan motor or clear the blockage preventing circulation (usually frost build-up from a defective defrost system part or blocked defrost drain).
Jun 13, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Frigidaire FRS26RLECS Side by Side Refrigerator Logo
143 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
