Question about Cuisinart CWC-1200 Wine Cooler
Stuck at 77 degrees!
I have the same problem. Fan runs but unit doesn't cool.
    Brigadier General:
  • 3,513 Answers
Hi
Do not assume the problem is related to the compressor or the sealed, hermetic system; these types of problems happen only rarely. Your unit may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the unit should be about 37 degrees Fahrenheit.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the unit are both set to cool.
3) Listen for the compressor fan, where the compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the unit will offer very little cooling or none at all.
hope you will be helpfull..
Thanks for contacting fixya.com
Posted on Sep 10, 2009
Unit not generating heat -
More in likely heating element has failed and needs to be replaced...
Mar 04, 2015 | Heating & Cooling
Hello. I have a Bryant 561CJ030-D AC unit. The fan comes on but doesn't seem to be cooling. We have had record high temps the past couple of weeks (over 100 degrees), and I'm wondering if the...
Is the compressor turning on? The fan may be running, but you will not get cooling effect unless the compressor is circulating refrigerant. It appears your unit is a 2.5 ton unit. What is the square footage of the space being cooled? Is the space insulated?
Aug 04, 2011 | Heating & Cooling
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
Central air unit out side will run non stop in hi temp cond and not cool very well, coils have been cleaned along with condenser and evap. it will run and turn off in early morning hours, freion is wher it...
Here is what you need to do to make sure your system is charged correctly go to the furnace take the temperature of to supply temp and take the return temperature at the furnace. You should have 18-20 degrees temperature difference if your return temp. is 77 degrees you should have 57 to 59 degrees. If you dont have these temps your system either wasnt cleaned properly or not charged correctly. If this helps please rate me and do a testimonial.
Jun 07, 2011 | Goodman Heating & Cooling
I've just moved into a home with an existing Armstrong Concept 10 A/C unit that's at least 15 years old. When I left for a 2-week vacation, the unit was working great. I set the thermostat to 77 to save...
Hello 93 The compressor caused the breaker to trip.A weak capasitor or burnt wire is a common cause.It sounds like the compressor is NOT on even though the fan is.It may need a new wire or maybe a HARD START kit to help restore operation.Call for help.HS kits are not expensive.NO damage results from leaving it on, the problem would have happened anyway even if you went on vacation or not.The curcit breaker stopped it.Its worth fixing.
Aug 30, 2010 | Heating & Cooling
Air conditioner constantly running, not cooling house
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
Magic Chef MCWC8DSCT Wine Cooler
I had the same problem. I fixed the problem by replacing the main cooling fan that is mounted over the electrothermal cooling unit.. Fan can be ordered from RepairClinic.com.
Sep 16, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Cuisinart CWC-1200 Wine Cooler Logo
806 people viewed this question
Top Cuisinart Furniture Experts
Maxumized
Rabbit Brains
Rabbit Brains
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
