Question about Sony Cyber-shot DSC-W50 Digital Camera
Same issue same thing where do i get a new zoom motor
Put new film in and the motor wouldn't stop running. samsung 1150
maybe the system of the motor its broken. you put the film but the system cilinder is broken and dont charge th film. you need to go to the technical service.
NEW Samsung Slim Zoom 1150 FILM Camera 38 115mm ZOOM LENS with DATA BACK
Dec 14, 2014 | Samsung Cameras
ZOOM BUTTON STICKING..how do i fix this?
It is possibly an issue with the zoom motor, not the switch itself
Aug 21, 2017 | Agfa Cameras
Camera no longer does anything when the "zoom in" or "zoom out" feature is used. can't move the menu bar to the right, only to the left?!?!
Sad thing about point and shoot cameras they have a somewhat short life span and these types of issues are common.If you enjoy shooting I suggest a digital SLR camera.Factory service on a point and shoot can and probably will cost more than you spent on the camera when it was new.
Jul 18, 2009 | HP Photosmart M407 Digital Camera
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
Mac router compatability Zoom ADSL X6
Remember it takes two to tango, so the issue may just as well be in the iMac as in the Zoom X6... Regardless of that, I had the same problem (PC works fine, iMac and PC both get flaky when the iMac is powered up). Zoom tech support suggested trying RF channels 1, 6, or 11. The router was using channel 10, changing to channel 11 calmed things down. Zoom said there wasn't anything magic in those numbers, but their testing showed those channels worked best with the Apple products.
Dec 26, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Zooming in.
Your camera jumped out of gear. Open the front metal cover and disassemble all arm working with the main motor gear and try to reposition the red dot on the big gear with the small gear side by side. Presto now your camera is aligned. Place all arms back in order to your new alignment.you got your self a working camera. D: 3403 3404 mean error = some thing is block your lense and stopping the motored gear. For future referance don't drop the camera agian, next time it might be a expensive fix next time around.
Apr 26, 2008 | Olympus ? Stylus 500 Digital Camera
Sony dcr trv30 zoom inout problem
Wow, your camcorder is ill... sounds like an issue with the controller chip, This issue can be caused by all kinds of things, like moisture in the enclosure etc... I think this will have to be professionally serviced.
Oct 03, 2007 | Video Cameras
Power zoom not working
If you dont have rechargable NiMH batteries get these first. Alkalines just dont have the power anymore these newer devices need. If you do have NiMH and yours still having problems try and tap on the lenses as you power it on. As the motors that drive the autofocus and the lens mechanisim wear they draw more current. When this happens the unit draws more power then the batteries can supply and you run into problems. If your camera has a battery pack you may need a new one. They test them new and everything is good on paper but after some use things change.
Apr 24, 2006 | Olympus Camedia C-750 Ultra Zoom Digital...
Sony Cyber-shot DSC-W50 Digital Camera Logo
16 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
